T-Top Mystery
I finally got around to taking the T-Tops apart, removed all the stripping and the drivers side crumbled in my hand as I tried to remove it. (Wait, that is not the problem yet, be patient).
I managed to break apart the old bolts and get the trim off the t-tops, but not a problem, I had new stuff to put on there. (Wait for it).
I put the new trim on the T-top and it didn't match on the outer side. I thought, crap, I bought all of this which I can use the front and corner, but the driver side trim won't work. Okay, live and learn right? (Wait, still getting to the issue). Here is the new trim sitting below my ttop trim.
I find a T-Top from a parted out 77 and buy the drivers side. It arrives today and I begin to take it off to put on my 77. It isn't the same. This one has two pieces of stainless trim to it, and mine only had one. So being the dull tool that I am I said could there be something I am missing in the T-Top weather stripping.
Here is the new Ttop with two part assembly.
Sure as heck, the stripping material I have will work well with the two piece design of the t-tops I don't have, and not with the t-top design that I do have.
So here we go for those of you patient enough to follow this issue. I still have a damaged driver side outer trim AND I don't have weather stripping that will fit the t-top style that I own.
This is the front locator of my 77 Ttop.
This is the front locator of my replacement Ttop.
And this is the rigid weather strip from my Ttop (the side that didn't rust away) and you can see the part number
So please, can some one out there tell me what I need in the way of a replacement part for my 77 Ttop and what Ttop weather stripping will work with my original tops? Part number any good as a reference?
What a mess.
Your help will be appreciated. Thank you.
David
This is an easy one, in 1977 there were two different design's on the roof panels.
Early and Late.
Tops with the rigid weatherstrip are late tops. Cars with the two piece design retainer are early.
Early cars used a retainer to hold the weatherstrip over your head, Late had metal in this part of the rubber and did not need the retainer. You need to find a 77 Late molding for your top.
Here, this will help you understand.
Early tops click here:
http://willcoxcorvette.com/repairand...lp.php?hID=115
Late tops click here:
http://willcoxcorvette.com/repairand...lp.php?hID=116
Willcox
Anyone know where I can find used good condition 77 Late Drivers side molding?
The search continues but thank you for the help, much appreciated.
David Howard
David Howard
Lots of random stuff floating around in there, and some people with parts cars.
W
Early and Late.
Willcox
Also, my extra T-Top without the interior pad is now worthless to me so I will try and see if anyone wants that as well.
Live and learn.
Thanks for your help.
David
The proper application for the weatherstrip is 1970 – 1977 early. 1968-1969 Cars used a totally different weatherstrip. The 70-77 weatherstrip will work as a replacement for a 1968-1969 car.
w
w
Had a similar experiance with my '75. Got new weatherstripping and the T-top rubber didn't fit. Come to find out the mirror T-tops were different than the painted. Ordered a correct set for the mirrored and now both sets of tops have new rubber.
TommyJ
Seems that way sometimes doesn't it? I had a hard time sleeping last night so I stayed up late and worked on the car research. I am a firm believer in measure three times, cut once, so I was researching all the data on the calipers, brakes, etc. I had heard from the group and was making some prints of "how to". I am ready to dig in tomorrow so I won't be online much and Sunday I have a car show so won't be on much at all. It runs in spurts actually. Lots going on though. Best regards,
David
I'll try to email you tonight if I see something.
Best regards,
David
