wiper door and headlights go up simultaneously
Old Aug 29, 2008 | 12:35 PM
CorvetteBobWi's Avatar
CorvetteBobWi
Default wiper door and headlights go up simultaneously
Anyone ever run into this before?
Old Aug 29, 2008 | 01:43 PM
65GGvert's Avatar
65GGvert
Sounds like someone has either spliced into or connected incorrectly the wiper door and headlight ***'y vacuum lines.
PS Has anyone else noticed how many questions are coming in lately with no mention of year of car and no profile filled out? I guess we need to use ESP to answer.
Old Aug 29, 2008 | 02:25 PM
baxsom's Avatar
baxsom
well in most states you have to have on your headlights when you need your wipers
maybe the car knows
Old Aug 29, 2008 | 04:57 PM
Alan 71's Avatar
Alan 71
The diverter valve solenoid is turned the wrong way! An easy fix!
Come on, a little information would help get you some help!
Regards,
Alan
Old Sep 2, 2008 | 11:41 AM
CorvetteBobWi
Sorry guys...its a 70 small block...the headlights and wiper both go up at the same time when you turn on the headlights, or if you use the headlight door override switch, but the wiper door will open independently with the wiper override switch.
Old Jul 29, 2009 | 12:02 PM
ace_cobra's Avatar
ace_cobra
I have the exact same problem, what is the diverter valve solenoid ?
Old Jul 29, 2009 | 04:34 PM
Alan 71's Avatar
Alan 71
Hi AC,
I was trying to make a joke. Looking for more information.
Sorry!
Regards,
Alan
If your question is serious I'd start by looking at Wilcox's vacuum hose routing diagrams and getting Dr. Rebuilds Trouble Shooting Guide. I often hear that the wiper door and head light doors open and close at start-up, but not that the wiper door opens when you pull the headlight switch. Is that what you have?
Old Jul 29, 2009 | 08:54 PM
CCrane65's Avatar
CCrane65
And what is the event that initiates it? Turning on lights?, Wipers?, both, starting car?, turning off car?, pulling wiper override?, headlight override?, both?
Give us some more info. Have you made any changes lately? When did it start?
cc
Old Jul 29, 2009 | 08:59 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Sounds like there is an error in the vacuum hose routing. Let me see if I can find Wilcox's diagram and I will post it here.
Here is the link to Wilcox's Diagrams. Look for the one for your year.
Old Jul 29, 2009 | 09:26 PM
CCrane65's Avatar
CCrane65
Sounds like the white stripe hose for the wiper door relay is t'd into the headlight control circuit.
cc
Old Jul 29, 2009 | 09:54 PM
ace_cobra's Avatar
ace_cobra
it could be the hoses are mixed up on the headlight switch, or the headlight switch is not holding vacuum to the wiper side as it should. I had a bad switch, replaced it and now the system works again...for a little while!
To wiper door and headlights go up simultaneously
