82 EFI Conversion
Old Aug 29, 2008 | 01:59 PM
Dirtbuster1's Avatar
Dirtbuster1
Default 82 EFI Conversion
Has anyone out there changed an 82 CFI or different type engine to a different type fuel injection system. I am concerned about hood clearance that might be a problem. If any has done this could you please share your experience with me.
Old Aug 29, 2008 | 08:42 PM
Durango_Boy's Avatar
Durango_Boy
If you decide to go with Vortec heads and Vortec fuel injection I have a complete Vortec manifold complete with TB and injector system, both upper and lower manifolds and all the manifold accessories.
Old Aug 29, 2008 | 09:44 PM
Dirtbuster1
Don't know how much that would cost, and will it fit under the stock hood. PM me the info.
Old Aug 30, 2008 | 12:22 AM
MN-Brent's Avatar
MN-Brent
http://ncarboni.home.att.net/NCtpi.html
This site has been around for a long time now. Maybe this can help.
Otherwise I have read that some folks that have done 82 conversions to other intake set-ups, wheather carbed or EFI, have to cut out the cold air inlet tube on the underside of the 82 hood.
Another option could be to use an 80-81 hood.
B...
Old Aug 30, 2008 | 02:07 PM
Dirtbuster1
This is a old but good article. I'm not sure if I want to start cutting on the hood. I was told the 1986 - 1992 GM TPI unit should work, but it sounds to be that would require mods on the hood.
Another thought I had was to see if someone offered an aftermarket ECM & wiring harness to simplify the CFI modification. I really don't hate the hardware that GM installed, just the poor engine management system.
Thanks for the reply and any more suugestions.
To 82 EFI Conversion
