New Ignition switch does not have Accessory position
Old Aug 29, 2008 | 06:09 PM
tristan69's Avatar
tristan69
Default New Ignition switch does not have Accessory position
I bought a new ignition switch from Ecklers a few months ago as my old one would accept any key.
Upon installing it yesterday I noticed that it does not have an accessory switch when turned counter clockwise.
I did not recall if my old one did either, but the owners manual says that there was one in 69.
Is this correct or did somehow it get installed wrong?
Funny thing is every other position works.
The steering wheel lock also goes click click lock and before it just locked.
Any advise on how to fix if possible would be of help.
Old Aug 29, 2008 | 06:31 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Adjust the start switch on the column, with relationship to the starter key position.
I metal rod connects the 2 together.
Lossen the mounting screws and adjust to correct position.
69Vett
Old Aug 29, 2008 | 07:13 PM
...Roger...'s Avatar
...Roger...
Are you pushing in while trying to turn back?
Old Aug 29, 2008 | 07:15 PM
tristan69's Avatar
tristan69
69Vett
Do you have picture showing what you mean?
I cant visualize it.
Will this give me the accessory and help the steering lock?
I am looking at Jim Shea's papers, but only find pre 69 switch and not much detail. I will keep looking.
Old Aug 29, 2008 | 07:16 PM
tristan69's Avatar
tristan69
Yes
It goes a little, but does not allow anything to turn on so it is not there.
Old Aug 29, 2008 | 09:23 PM
...Roger...
Originally Posted by tristan69
Yes
Its probably a misadjusted ign switch but awhile back there was thread where one of the guys had an extra ring at the bottom of the lock hole.On the bottom of your ign. lock is a ring with a tab on it.Make sure your old ign. lock still has it on there.If not it could still be inside.
Old Aug 30, 2008 | 01:18 AM
tristan69's Avatar
tristan69
Old one is in the garbage, which just got picked up.
Anyways I will take it apart and look for a tab?
Any pictures?
Old Aug 30, 2008 | 09:41 AM
69Vett's Avatar
69Vett
let's clarifiy I assume you replaced the key lock,
where you insert the key. (it is not the switch).
a long rod connects the lock to the - Ignition switch,
which is located on top of the column, behind the dash.
now Adjust the the Igintion switch position,
if you replaced the lock properly. 69VETT
Next time, NEVER throw out old part until problem is fixed for a week or 2.
Old Aug 30, 2008 | 10:01 AM
...Roger...
Any pictures?
Here is the ring that "could" be left behind.
EDIT-here is the thread from where I lifted the pic.I could not find the thread where the guy had said he found 2 of these in his column.I still cant believe the lock would go all the way in with 2 of these.
http://forums.corvetteforum.com/show...=cylinder+lock
Old Aug 30, 2008 | 10:51 AM
S489's Avatar
S489
it's been a while back, but i ran into the same problem. best i can remember, the lock cylinder was too far into the column and could not travel in the required distance to allow turning to the acc position.
the only way i found to make it work was to drill a small hole stratigically in the end of the lock cylinder and epoxy in a short piece of piano wire. this made the spring loaded cylinder stand out far enough in the other positions so that it would work in the acc position.
i wish i had a better description. i also felt like it a little bubba, but figured another lock cylinder would probably have the same problem, and it has worked fine for a couple of years . . . so far
Last edited by S489; Aug 30, 2008 at 10:56 AM. Reason: didn't finish typing the first time
Old Sep 2, 2008 | 01:21 AM
tristan69's Avatar
tristan69
Thanks, I looked at both key locks and they were the same.
it does click into a spot close to where you would think acc is but nothing has power in this position.
Not as if I ever used it, just would like to know that it works.
Thanks again, I am going to leave it for now as I am prepping for paint.
Old Feb 28, 2023 | 07:18 PM
Sqr's Avatar
Sqr
69Vett
this
Old Feb 28, 2023 | 09:01 PM
speedreed8's Avatar
speedreed8
this. Was 15 yrs ago 😕
To New Ignition switch does not have Accessory position
