My 383 (550 HP on race fuel, runs like crap on pump gas) is being replaced under warranty and the builder gave me an option: he can build me a new 383, but with different heads so it will run as well on 93 as this one did on pump gas, or build me a 402 instead, which would also run around 550 HP, but on 93 octane instead so I wouldn't have to cut it with race fuel.
That's what I'm not sure of - would the 402 be a better choice or should I just get another 383? I don't care if it's more power than before, I'm just thinking in terms of reliability etc. Broke one rod already with the 383 (and I wasn't really hot-rodding it either, in fact I haven't even been to the track with it yet) and now there is another knock, so the whole thing is being replaced. He gave me the option of the 402, said he could put in a rev limiter at 5800 RPM's and it would still make as much power as the 383 did without one, and it would run as well on pump gas as this one did on 110 octane.
Seems like a better option on the surface, but wanted some other opinions before I gave him the go ahead on the 402.
This 402, will be a small block?..... If given the option, I'd go for the 402. It's easier to make power with more cubes and the engine will be more street friendly with more peak torque to go along with your horsepower.
Is there any reason not to do the 402?
I have a 78 383 stroker that I built myself with some guidance from a friendly machinist. It's full roller with forged internals (H beam rods). My machinist fully balanced my crank with the flywheel on it. It's hard to mess up a motor with some light guidance. I built it myself so that I knew it was done right- down to the crank bolts. I would find another motor guy, because it sounds like he messed something up. My 383 runs on 93 octane- I went with -12cc inverted dome pistons which create 9.8:1 compression. I am partial to the 383 because you can create a little more high end RPM, the 402 might be more restrictive but offer more torque- it's a tradeoff and personal preference..- Daddybugs out.
First off your being BS'ed if your making 550 hp at sub 6000 rpm. Find a real engine builder
Real engine builders don't make 383's or 402's I would believe a 396 or 408
Real motors do not break rods. I've built and owned 9000+ rpm small blocks and valve trains always fail first.
Tell me what you want and our shop will build it for you. or just get online and get a bad as pump gas motor.
I don't build 383's because for the same price you can do a 396. Solid roller and do 7500 every day you hop in it.
