Tri-power fast idle concern
I have replaced the bi-metal spring and upon a cold start after pressing the accelerator pedal to ful stroke the bi-metal spring does place the cam to the high speed idle position. However when I start the car it does not stay on the high speed idle cam position and the engine stalls.
What do I do next to get the engine to stay on high speed idle on a cold start?
Thanks,
Mike
http://www.holley.com/data/TechServi...ded%20View.pdf
http://tocmp.com/manuals/Carbs/Holle...C-SixPack.html
Hopefully This information will help you with the issue you are having. Good luck
