Heat ect. Fuel temp
Old Aug 31, 2008 | 06:11 PM
Lilfur's Avatar
Lilfur
Default Heat ect. Fuel temp
I seem to have a problem with heat. First ? is where should the fuel line run. The reason I ask is that I just noticed that my metal line coming from tank in the engine compartment comes up the frame then when it bends over it the fuel pump area it is about 3/8 inch away from the exhuast manifold. When my engine get hat like idle for 20 to 30 min. I start to have fuel supply issue to carbs. I used a laser and at this point the metal fuel line is about 192 degrees. Could the fuel temp be a issue? Because till the fuel gets to this point I have NO fuel problems.
