72 console removel
Old Aug 31, 2008 | 06:17 PM
ettevroc 37's Avatar
ettevroc 37
Default 72 console removel
The part that the amergency brake lever sits in. I have all side screws out and theres something holding the back where it comes in contack with the back wall
Old Aug 31, 2008 | 06:32 PM
dmayhew's Avatar
dmayhew
There is a bolt that holds in in that you get to after removing the center storage compartment liner behind the seat.
You have to remove the trim that goes across all 3 doors.
It takes a 7/16" socket on an extnsion
David
Old Aug 31, 2008 | 08:54 PM
DC3's Avatar
DC3
Originally Posted by dmayhew
There is a bolt that holds in in . . .
David
Yep. I was able to get to the bolt through the jack compartment without removing the trim and center storage but it wasn't easy. Small hands and holding your tongue just right helps. What I didn't have but might work well for this bolt is a flexible shaft socket extension.
DC
Old Aug 31, 2008 | 10:18 PM
ettevroc 37
Finding the bolt in the back did the trick. Better than a sawsall. Thanks for the help. Allen
Old Aug 31, 2008 | 10:28 PM
randommj's Avatar
randommj
I was able to get to it without removing anything, through the jack storage I think
Miles
To 72 console removel
