This question may seem stupid to some, but it is my first experience with an engine stand. Is there a preferred method to attach a SBC to one of these four armed stands? Should certain bell housing holes be used to distribute load evenly? Most important, is there anything NOT to do when mounting to prevent damage to block? Thanks for any advice!
There's not really a wrong way to do it. The block is made of iron and will be strong enough in any bolt location, but I would recommend spreading the arms as far as possible. Best advice I can give is to remove the arm assembly from the stand and then bolt it to the block. It's much easier to pick up a 25lb engine stand than it is trying to align the block to the stand with a hoist.
Durango, where did you pull that engine from? Looks rough. If this was a before shot do you have the after as well? Good example of mounting the block though, love it when pictures can tell the story.
David
77Sleeper
Thank you for the advice, the picture is as clear as it gets, even to me, LOL!
Thanks Durango!
You're very welcome, I took that just for this thread.
Originally Posted by pmullaly
USE GRADE 8 BOLTS!!!!!
Not those grade 5 bolts that are pictured above.
Also the correct length unlike those that a "shimmed" with the nuts
That engine came into the garage last minute and I didn't have any bolts short enough so I did a quick shim until I could get out and get more hardware.
To be honest the grade 5 have never been a problem no matter what engine I have been working on. I usually have grade 8 on hand but when I run out I use grade 5 and even with my Dodge big block projects I have NEVER had a bolt fail on me.
David
77Sleeper
That engine sat outside for a while I think. It was covered under an awning but it got plenty of surface rust. I haven't torn into it yet but it does turn by hand. I don't have an after yet...and won't until it gets torn down and taken to the machine shop for some testing and work. If it passes I'll clean it up and rebuild it for a customer. It's one of a couple Vortec 350s I have and am working on.
Nope. That's an AFTER shot. [After it was "rode hard and put away wet"...] I'll bet it looks a mite better, now, Dboy.
Rode hard and put away wet... Love it.
I have heard many a great line here on the forum and I still love the line "drive it like you stole it..." Classic. Thanks for the laughs.
David
77Sleeper
A little note on bolt strength. A 3/8" grade 5 bolt has an ultimate strength in the range of 8000 lbs so you are looking at a total strength of about 32,000 lbs for the 4 bolts on the stand. Grade 8's would put you about 12% stronger so around 9000 lbs and 36,000 lbs total. Either way you have a significant margin of safety.
