Idle problem - a little long
My 68 L79 has had an issue whereby the idle (when choke is off and fully warm) will idle at a steady 750 RPM, but after driving, the idle will sit at 900 to 1000 RPM. It will then SLOWLY creep back down to a steady 750 if given a minute or two (or sometimes more.)
Now, if I blip the throttle while it's idling high, it will usually drop back down to 750 a little quicker. This same issue has happened with two different carbs (Both Quadrajets - one brand new and rebuilt.)
The timing is set per Lars, choke is fully off, throttle cable is new and not binding, stock everything under the hood with stock open air element..
When I pull the PCV and plug it, the idle will drop down all on it's own. So...I threw on a new PCV and took it for a spin - same deal - high idle at 1000 that slowly drops on it's own.
I'm out of ideas. Anything anyone can think of that I'm missing???
Could it possibly be that I need to "block off" part of the PCV to make it idle a bit lower????
I'm plum out of ideas.
Thanks in advance!
Q
I didn't try a different base gasket so I will give that a try.
The throttle shafts were a bit loose on the 1st carb. The 2nd which is on it now was nice and tight with no play.
Thanks in advance!
Q
tim
Thanks in advance!
Q
This cured my problem hope it helps you .
I noticed idle scew was not touching plate so I set idle speed with idle screw to 1200 rpm which is too high then unscrewed jets equally until
I reached desired rpm for me it was 800rpm. Never had problem since.
