Help - 1969 Cowl Weatherstripping question??
Old Sep 1, 2008 | 09:05 PM
mickey67vet's Avatar
mickey67vet
Default Help - 1969 Cowl Weatherstripping question??
Hi all,
Does anyone know if there is a rubber seal underneath the upper cowl bonding strip near the windshield. The location is where the small stainless pieces would attach to the fiberglass but the seal appears to be under the bonding strip on my car. I am doing a reattachment of a replacement front end and the car has weather the elements for some time before i got it and I want to replace the hard pieces before reattaching the nose and do a full body off restoration.
Also, Is Corvette Rubber still in business or has someone bought them out?
Mike
Old Sep 1, 2008 | 10:32 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
This was actually what was called the lower pillar weatherstrip and originally was made to the windshield upper pillar. It went right under the edge of the front fender in the door jamb opening and was attached after the front end was installed.
Over time they come apart, but installing your front end is crucial and you should have this part to make sure it fits before painting the car.
We only carry Corvette Rubber parts and have the windshield pillar with the lower section attached. Or you can just purchase the lower section separate. Here is the link.
http://willcoxcorvette.com/advanced_...lar+post+lower
Willcox Inc.
Old Sep 2, 2008 | 05:41 PM
Alan 71's Avatar
Alan 71
I thought we'd be talking about the wedge shaped piece of hard rubber that was between the inside of the rear upper corner of the fender and the cowl. The very top of it was hidden by the SS fender trim. You could only see it if you looked down along the windshield corner under the SS trim. This is a piece of seal that I haven't seen for sale in years.
By 71, Chevrolet had done away with the 'formed' piece and was just globing a whole bunch of what looked like butyl rubber to fill the space.
Regards,
Alan
Old Sep 5, 2008 | 09:36 AM
mickey67vet
Thanks Alan 71, that was the pieces I was looking for. Willcox, thanks for the info. Looks like I'll have to make my own before I reattach the front end.
Again thanks
Mike
Old Sep 5, 2008 | 03:20 PM
Alan 71's Avatar
Alan 71
Mike,
Try Dr. Rebuild. He had them years ago, then they became N/A, but he might have them again. It's worth a call.
Regards,
Alan
Old Sep 6, 2008 | 09:53 AM
mickey67vet
Default More on weatherstripping
Thanks , I know of the good Doctor and we'll chech with him. I did check another 69 that a friend is parting out and that car is an earlier build than mine by about 15,000 car and this car has just globs of butyl rubber attached whereas mine has what appears as a formed piece. I am not going even bother trying to think about how that happened and I may just go with the glob and check with a few NCRS friends and see what they say.
Thanks Mike
To Help - 1969 Cowl Weatherstripping question??
