Is this a good deal?
VIN # 194678S40xxxx,
Build date - Oct 19, 1967.
Paint - 976 Lemans Blue,
Trim - std Black,
Block - 3916321 correct date .060 needs rebuilt,
Heads - 3919842 aluminum L-89 heads. Not correct for car.
Crank - #6223 steel 427 crankshaft std-std,
Intake - original 3919852 build date 8-28-67,
Carbs - original/rebuilt center #4055 date 784, outer # 3659 dates 782, 794,
Rear end - FA code 3.70 Heavy Duty Positraction, original.
Distributor - 1111296 original, K66 with T.I. standard L-71
No dreamers please. Car is worth Big Bucks when done. $ 16,750.00
http://s279.photobucket.com/albums/k...3109b5e50b.jpg
(only picture i have)
Also does anyone know if it is a 4-Speed Manual Transmission, close ratio, hvy dty how can you tell.
Thanks.
