Getting LS Fever
Old Sep 6, 2008 | 08:31 PM
nastee383's Avatar
nastee383
Default Getting LS Fever
I'm thinking REAL hard about getting GM P/N19171224, 480hp@5750, 475lb/ft@4500. Fuel injected 376cid LS3 with Hot Cam.
Old Sep 6, 2008 | 08:45 PM
Gordonm's Avatar
Gordonm
Me too! Just don't have the cash right now for it. The LS3 is a great motor.
Old Sep 6, 2008 | 09:40 PM
77TexVette's Avatar
77TexVette
You guys are reading my mind. I have been debating back and forth between rebuilding the existing engine, buying a "regular" 383 stroker or going the LS route.
I am almost positive that I will get that P/N LS3 to go along with my TKO 600 and all the other stuff I am doing to the car.
Although I have been following a number of LS threads and web sites, I still am in the process of getting as much detailed information together as I can.
Baiscally, I want to see what all the other mods are I need to make so I don't end up being all too ignorant when the LS3 shows up on my doorsteps
Yes, dropping down 6k+ on the engine will bring a tear to my eye, but I think it'll be the right choice. My only fear is actually that it'll take another couple $k to get all the other LS-mods completed, e.g. ECU, A/C, pulleys, other accessories, etc, etc.
I'll spend a bit more time wrapping up my research in the next month and will post details on here. Of course I'll share pics once I actually get started.
Time to take the LS plunge
Old Sep 6, 2008 | 10:27 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Link to both of my LS Videos on You Tube
Old Sep 6, 2008 | 10:45 PM
nastee383's Avatar
nastee383
I did a little research after the initial post and everything may come to about $9K or so. $800 for the controller kit, $750 for the serpentine kit and porbaly another $800 for misc. stuff. Not to mention the trans/controller for it. My enthusiasm has been somewhat dampened but not totally eliminated.
Old Sep 6, 2008 | 10:55 PM
Eddie 70's Avatar
Eddie 70
You do not have to buy brand new stuff. I bought a motor out of an 02 SS Camaro that has 27k on it. Granted it is not an LS3, but those are becoming more and more available in the market. I bought my motor with the harness and all the accessories. It even had long tube headers and the y-pipe from the camaro. I gave the headers and heads to my son for his 2000 camaro. I picked up a set of 243 heads and a cam. I now have essentially a cammed LS6 for my 70. In the videos, the car fires on the first time we turn the key. Granted it does not run as good as it can, but it will get there.
Don't give up yet if its what you want.
Old Sep 6, 2008 | 11:25 PM
Richard454's Avatar
Richard454
I'm also looking at a LS set up too-
Weighs less and more horsepower. I looking at these motors - going w/ either the LS 376/515HP GM part # 19171225 (about $7K )or the LS 364/440HP GM #17802134 ($5K) LSx crate motors.
Running a carb rather than Fuel injection- and from my understanding- plug in a MSD box (about $350-and ALL my ignition is DONE-just add 12volts) and bolt on a carb adding a low 6-7PSI electric fuel pump system.
Don't have to worry about ECM-fuel return lines-modifying tank -loud pump-drive by wire-harness-O2 sensors etc. And I get to use my L-88 hoods chamber.
BTW- Nice work Eddie-I've been following your swap.
515HP!! and weighs 416lbs- 200 lbs LESS than a ZZ502-and cost about the same when you add a carb.
Old Sep 7, 2008 | 12:52 AM
cv67's Avatar
cv67
St. Jude Donor '05
LS3 is one of the best engines ever made, cant kill them.
My next one will be something similar but carbed.
Good prices on pace performance for what youre getting.
Old Sep 7, 2008 | 03:18 AM
RunningMan373's Avatar
RunningMan373
A Carbed LS3,, for 5 grand. what a cool idea! Where's GMs Santa hat?
Life don't get any better then that...
Old Sep 7, 2008 | 08:47 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Originally Posted by Eddie 70
Eddie, when you said you want to install a bigger cam you ment it.
Old Sep 7, 2008 | 08:56 AM
Gordonm's Avatar
Gordonm
That is about what I came to. To do it the way I wanted to go it would be about 9 to 10K. Too much for right now. If I'm going to go to a LS motor FI would be a must. Looks like I'll stick to what I have for a while.
Old Sep 7, 2008 | 10:12 AM
mrvette's Avatar
mrvette
I have done some sniffing around also on that topic and to replace what I have for something similar in power but LS based....I would have to put out some 5 grand.....with a used engine, unless I got awfully lucky somehow....
headers, drives, injection, I passed on a craigs list engine complete for 1000 bux.....NO induction, drives, harness, computer, headers, at that point it's too much....
it was a '99 vette engine, supposedly....
Old Sep 7, 2008 | 02:45 PM
Eddie 70's Avatar
Eddie 70
I think it sounds bigger because the motor is idling on the stock camaro tune. Idle for a stock camaro is around 650 RPM. It makes it sound like a beast. I bumped it up to 1000 just so I could drive it home and it would not die on me all the time. I am going this week to finish the exhaust and then I am going to start doing some tuning on it.
Cam specs..G5X2-232 240 .595 .608 LSA-112
The LS motor can handle a bigger cam easier than a small block.
Old Sep 7, 2008 | 03:48 PM
nastee383's Avatar
nastee383
I know I probably could hunt around for a good used motor and, accessory drive harness, etc. but good or bad I'm the type that'll spend a little more $$ for peace of mind. The motor I'm interested in, the controller kit is all inclusive and engineered specifically for that motor. To me that means get it installed and it's gonna work correctly.
As for the 515 horse carbed LS3. That's a nice piece too, but I feel if I'm going LS3, I'm going with the best technology available. I already have 2 carbed hotrods. If I change motors again I want to go FI w/o laptops and staring at graphs trying to figure out this and that. I guess the older I get the easier I want this stuff to be.
I'm not giving up on an LS motor. I just need to commit to the cost. I suppose I could sell my all forged, Canfield headed 383 in my Jimmy and offset some of the cost. The 396sbc in the Vette would go in the Jimmy and the LS3 would go in the Vette. Decisions, decisions, what's an old gearhead to do?
Old Sep 7, 2008 | 05:07 PM
greg75vette's Avatar
greg75vette
I've wanted to put a twin turbo LSx into an older car for years now; longer than I had my vette; longer than I was even interested in vettes. I wanted a resto-mod with as many updates as I could that would be a head turner but also came with little power stock and was somewhat undesriable compared to its sisters' years. I have a '75 L-48. I think it fits the above criteria. I may lax on the twin turbo idea just because I still can't seem to find a way to plum it in a C3 (intercooling is a must) without serious modification to the front end.
I plan on getting the engine and necessities together in about a year and the transformation next winter (hopefully). Once an LSx/6 speed are in, I'll drive it like that and decide to go NA or TT later on.
You could say I have the LSx bug...
Old Sep 7, 2008 | 09:26 PM
Jay71's Avatar
Jay71
Default I have LS fever too !
Add me to the list guys ... I'm currently saving for a used LS2 motor & 4 speed auto transmission. I went to Carlisle and took a ton of pics of all the restomods w/ LS motors. I can't wait !!
Old Sep 8, 2008 | 12:03 PM
Todd M's Avatar
Todd M
Where did you find a serpentine kit for $750. Most of the aftermarket kits I have seen were all inclusive and cost in the range of $1700 to $2000. I bought an LS-1 out of a 2002 Camaro SS. It had 7000 miles on it. It needs all the ancillary stuff though.
To Getting LS Fever
Old Sep 8, 2008 | 01:00 PM
nastee383's Avatar
nastee383
GMPP p/n 19155-66, includes everything including the ac compressor for $769.95 at Pace Performance. Now if you want the fancy chromed aftermarket stuff you're looking at $2-3K.
Old Sep 8, 2008 | 05:02 PM
gkull's Avatar
gkull
for about the last three years nearly every racing C-5 has been showing up with the LS7 crate motors. TQ is a direct relation to CI. That is why I would not waste money building or buying sub 395 ci motors.
http://www.gmperformanceparts.com/En...2397&engCat=ls
Old Sep 8, 2008 | 05:13 PM
77TexVette's Avatar
77TexVette
Oh, yes. I wouldn't mind a LS7 at all
It seems the problem becomes where do you stop and how much money does it take? The LS3 appealed to me as the price quickly came "down" to about $6k vs. the $13k cost for a LS7.
The question for me might ultimately be a new LS3 vs. a larger displacement (400+) and modified LS1/2 platform. We'll see...
