Getting LS Fever
Old Sep 8, 2008 | 07:43 PM
SteveG75's Avatar
SteveG75
Originally Posted by nastee383
GMPP p/n 19155-66, includes everything including the ac compressor for $769.95 at Pace Performance. Now if you want the fancy chromed aftermarket stuff you're looking at $2-3K.
The actual PN is 19155066 but everything I can find is that this is the C5 accessory setup. This puts the PS pump pulley very very close to the driver's side upper A-arm. The Camaro accessory drive is supposed to be a better fit. Both Corvette and Camaro put the AC compressor low on the passenger side which will not work with the C3 frame. There are several solutions to relocating the compressor to high on the passenger side. I have seen several brackets for either the C3 compressor, C5 compressor or aftermarket Sanden compressor.
I am thinking about the same engine with an aluminum flywheel hooked to my current Tremec 5 speed. You can get a F-body setup of eBay and this place has some nice AC brackets. www.kwikperf.com
C5 accessory drive:
Camaro accessory drive:
Old Sep 8, 2008 | 09:21 PM
monza_man's Avatar
monza_man
I've got the bug too Planning on a procharged ls6 with keisler 5 speed in my '69 vert.
Old Sep 8, 2008 | 09:30 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
This will be a very nice setup for sure. I have the Keisler behind my LS setup too. I could not spring for the procharger just yet. Need to take care of some home projects first. Maybe in a few years if the LS in mine gets to be too tame.
Old Sep 8, 2008 | 10:02 PM
monza_man's Avatar
monza_man
Yeah I really wanted one for my 2002 Z06 but was short on funds for a while and went with a big cam instead. I've still got the FI bug and I figure.....how often do you ever see something like tha tin a '69
