Popping through exhaust under partial throttle
Old Sep 8, 2008 | 08:33 AM
lvrpool32's Avatar
lvrpool32
Default Popping through exhaust under partial throttle
I have a "popping" in the passenger side sidepipe under partial throttle (goes away under hard acceleration). Now I am running a multi carb set up and I know my vacuum flow is the same through all 4 venturi's.
I am thnking maybe a vacuum leak or maybe dirt in one of the carbs...anybody have ideas?
Nick
Old Sep 8, 2008 | 12:09 PM
Jon S's Avatar
Jon S
"popping" sounds like raw gas igniting in your hot pipe. Too rich? What carburetor(s) are you running?
Old Sep 8, 2008 | 12:22 PM
TopGunn's Avatar
TopGunn
Leaking exhaust gasket sucking in air.
Old Sep 8, 2008 | 12:38 PM
lvrpool32's Avatar
lvrpool32
I am running 4 Del'lortos (4 x 2 barrels)
The funny thing is that it was doing this when I first finished the 396 build and was using Pro Topline heads, I swapped them out for the AFR's last Spring and its doing the same thing. I changed the exhaust gaskets for the soft aluminum ones and they seal perfect. I am beginning to think its on the intake somewhere, maybe as the intake is in 5 parts (base and then 4 "runners") that maybe one of the runners on the passenger side isnt flat...might try and mist some water around there and see if it gets sucked in.
Old Sep 8, 2008 | 09:48 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Popping in the pipes is usually lean out.
I'd look for a vacuum leak first.
Old Sep 9, 2008 | 02:28 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Is your vacuum advance working?
How did your set-up your vac adv?
cardo0
Old Sep 9, 2008 | 02:50 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Old Sep 9, 2008 | 03:18 PM
lvrpool32's Avatar
lvrpool32
well..i posted this earlier on
I posted yesterday that I was getting a "lean" pop in the passenger side sidepipe on my car. I am running 4 x 2 barrels (Del'lorto's) and disassembled the 2 passenger side carbs last night looking for dirt/broken o-rings etc. Didnt find anything on the carb, but I did find that someone had drilled a 3/8" hole through the wall of the intake runners (the intake is in 5 pieces, a base and then 4 "Y" runners that bolt to the base. Basically giving one barrel, one runner per intake valve).
Anyway my theory is that as I can't see any visible leaks, that because of this hole I am pulling air not only through the carb venturi, but maybe through the next cylinder aswell, say on an intake/exhaust valve overlap. So my question is, on a "intake" cycle for cylinders 2, 4, 6 and 8 are the intake/exhaust valves of the next cylinder open?
Having said this, the holes are being closed as we speak.
a little more info....... I have a Comp Cams solid roller, 248 duration intake, 254 exhaust (at .050") so I dont know if that is enough over lap to have the intake and exhaust open when the adjascent cylinder is on an intake cycle. (by my calculations when #2 is on intake, #4 is on exhaust (possibility of overlap???) could that be creating my lean condition????
Nick
Old Sep 9, 2008 | 06:55 PM
ram82fire's Avatar
ram82fire
Hi Nick are you running a crossram ?
Geo
Old Sep 9, 2008 | 07:49 PM
lvrpool32's Avatar
lvrpool32
No, running a vintage Mckay downdraft intake. Will be replaced over the winter with a wilson sheet metal one i am working on.
Nick
Old Sep 9, 2008 | 08:42 PM
ram82fire's Avatar
ram82fire
Have you balanced them using a manometer ? The dcoe has a port that allows vac checks in each IR . I have no knowledge of the model you are using .
GEO
To Popping through exhaust under partial throttle
