Uneven Headlights
Old Sep 9, 2008 | 10:05 AM
dburgjohn's Avatar
dburgjohn
Default Uneven Headlights
my new toy's headlights won't play well together. Turn on and the passenger comes up all the way before the driver moves. Turn off and the passenger stays up until the driver is all the way down. The driver has a new servo while the passenger looks original. Have checked for leaks with a vacuum pump, but find none.
Old Sep 9, 2008 | 10:18 AM
...Roger...'s Avatar
...Roger...
Switch your hoses at the relays and see if the issue reverses itself.
Old Sep 9, 2008 | 02:08 PM
jetnoise's Avatar
jetnoise
would swapping relay side to side accomplish the same test?
Old Sep 9, 2008 | 03:01 PM
...Roger...
Yes. If it follows the relay then you know where the problem is other wise its probably a leaky actuator.
To Uneven Headlights
