Rear upgrade
Old Sep 9, 2008 | 10:30 AM
Simmo's Avatar
Simmo
Default Rear upgrade
Im looking at upgrading some parts in the rear.
Toms list a billet steel cap inside to replace the cast one. Am I right in thinking this will need to be align honed after fitting?
Old Sep 9, 2008 | 11:30 AM
77TexVette's Avatar
77TexVette
Not sure about align-honing the way you would do with an engine. However, any cap should be properly fitted to have the right "tightness" on the races/bearings that it clamps down.
You'll find details in some of the more popular differential rebuild links on here.
Also, I am just having my whole differential strengthened and rebuilt mainly with Tom's Diff parts. The only item I did not go for was the upgraded cap as it seems that something else would break before that part. Might be a nice insurance, of course....
Old Sep 9, 2008 | 11:49 AM
GTR1999's Avatar
GTR1999
The cap has to be fit. I use Tom's parts in my work and will be building 12 bolts soon. Let me know if you have any questions.
Old Sep 9, 2008 | 01:36 PM
tracdogg2's Avatar
tracdogg2
The steel cap always has to be fitted. Depending on the housing it could require a minor touch up to major machining. The cap is good upgrade for the 12 bolt conversion that Gary and I will both be doing but you will almost always blow up the stock 10 bolt carrier before you break the stock cap.
Mike
To Rear upgrade
