L48 vs. L82
Old Sep 24, 2008 | 08:00 PM
dstaley's Avatar
dstaley
L82's did not come with trap door oil pans. I'm not sure about some of that other stuff you rattled off.
Old Sep 25, 2008 | 01:42 PM
fauxrs2's Avatar
fauxrs2
http://earchitect.50megs.com/corvette/vspecs.html
L-82 heads are large valve heads, not that they flow significantly better for it though...the bottom end of a 78 L-82 is for all intents and purposes the same as the LT-1 of yore...the cam being different and the compression being lower...a stellar starting point for a build up.
all that said, a L-48 will respond to all the mods a L-82 will and you will need to do the same mods to both anyway so starting with a L-48 is just fine.
Old Sep 25, 2008 | 01:51 PM
dstaley's Avatar
dstaley
Wow, that is some GREAT info! I sure wish it included piston dish volume for the L48, I've been looking for that all over!
Old Sep 25, 2008 | 03:02 PM
bytor's Avatar
bytor
Here's a good link that shows the differences between L48 vs. L82.
http://www.vettefinders.com/78Registry/1978spec.html
Old Sep 25, 2008 | 04:14 PM
fauxrs2's Avatar
fauxrs2
LOL I created that page
Old Sep 25, 2008 | 04:26 PM
dstaley's Avatar
dstaley
Is there an equivalent 1976 page?
Old Sep 30, 2008 | 08:42 PM
377's Avatar
377
IF i remember right i think it has a door in front of the pickup like the lt-1 pan
Old Oct 1, 2008 | 08:24 PM
67-73-76's Avatar
67-73-76
Go to NHRA.com.
Click on the Rules tab.
Then click on the Stock Car Classifications tab.
Then click on the Engine Blueprint menu.
They have all the specifications for every production engine made.
The chevy section goes back every year to 1955.
Its an xcel spreadsheet you can download.
Old Oct 1, 2008 | 09:02 PM
dstaley's Avatar
dstaley
Originally Posted by 67-73-76
Go to NHRA.com.
Whoa, thank you!
Doesn't it seem odd that it lists all 350's as 10.2:1 or 10.3:1 compression???
It does give the stock L48 piston "sump" size though- 9.92cc's. I've been looking for that for months!
Old Oct 4, 2008 | 07:48 PM
NHRalph's Avatar
NHRalph
The block casting numbers are the same for L-48 andL-82, Head casting nubers are the same also. L-82 does have different pistons, larger valves, forged crank, 4 bolt mains and better cam but physically, they are the same. As for 2 bolt vs. 4 bolt not that much difference, even Callaway used 2 bolt blocks when he frst started. You can take an L-48, changed cams and you wont even notice the difference. 2.02 valve vs. 1.94 will be marginal on the street. BUT, that siad, I'd get another block and build it up, save the original engine.
