L48 vs. L82
Old Sep 10, 2008 | 07:34 PM
Dacksoldier's Avatar
Dacksoldier
Default L48 vs. L82
What is the physical difference between an 1978 L48 and same year L82?? can you make a L48 perform just like an L82??
Old Sep 10, 2008 | 07:40 PM
mrvette's Avatar
mrvette
Short answer, no, not really, heads, cam, pistons, and some say also the block is 4 bolt mains for the L82.....
which will not mean much for hotrodding for street use....
in fact the late 70's heads are rather poor no matter which engine....thin castings....lo flow rates, which suited the mild cams, but limit performance....then there are the cat *** trophic converter requirements, and single exhaust...the list is long, and the cures vary wildly depending on your local .gov inspections....
Old Sep 10, 2008 | 09:04 PM
Oldguard 7's Avatar
Oldguard 7
Yes it can be done but as the previous poster mentioned,you would have to get better flowing heads. The L82 cam is the same as the L46 engine. Pistons in the L82 engine are forged with a single trough relief.
Old Sep 10, 2008 | 10:59 PM
Scott Marzahl's Avatar
Scott Marzahl
Not only are the pistons forged but so is the crank for a stronger bottom end. Basically if you want to swap heads, cam and intake you can make a very good running L-48 assuming that the short block is in good condition.
Old Sep 10, 2008 | 11:08 PM
martinsw's Avatar
martinsw
Why even try? L82 only had what, 220 hp vice 185 for l48. Better just to gut out the l48 and build up the sbc using aftermarket parts and get a lot more than 220 hp IMHO. the two bolt main should handle well over 400 hp shouldn't it?
Old Sep 10, 2008 | 11:49 PM
dstaley's Avatar
dstaley
Yep, well over 400hp - especially with quality (ARP) bolts or studs.
The Vortec head swap is very popular, and will nearly double the original L48 power output with the right intake, camshaft, headers, and dual exhaust. 360hp is well within reach, forget about 220hp.
Old Sep 11, 2008 | 12:49 AM
Enersis's Avatar
Enersis
my buddies motor in his camaro is 2 bolt, with 600 hp, i wouldn't do it, but its holding up just fine.
Old Sep 11, 2008 | 03:51 AM
Dacksoldier
well the reason i want to keep the L48 cuz its matching number.. but i'm thinking against that now and if i can just find a 427 or 502 that my friends dad gets rid of all the time(he does super comp drag racing)
kk now my question is can i put a 427 or 502 in a 1978 L48 vette?
i'm guessing that its easily possible.
Old Sep 11, 2008 | 08:32 AM
dstaley's Avatar
dstaley
Sure, the chassis was designed to accept big blocks and little was changed between the early 70's and your 78. There is a wealth of information on this forum about the details, but the motor mounts will simply bolt up. You'll have to work through details like alternator and power steering brackets, A/C compressor brackets (if you intend to keep/install it), and the radiator fan shroud. Hood clearance will need careful attention too.
Old Sep 11, 2008 | 12:05 PM
7T1vette's Avatar
7T1vette
If your buddy's Dad is 'done' with a 502, it's because it is WORN OUT! Don't put an abused, tired engine in your car...you'll just be asking for trouble.
Old Sep 11, 2008 | 12:20 PM
dstaley's Avatar
dstaley
And, you know this HOW?
That's one good reason for being 'done' with it, but others are: changes in rules, different car, wanting to compete in different class, wants new/bigger flavor-of-the-month engine, etc...
I bought a 396 from a buddy that was "done" with it in his T-bucket. He wanted a 454. There was no sensible reason for it, he just wanted it. I bought another one from a different friend that sold the car but the new owner wanted only a roller.
Give the guy a break, there are a wealth of reasons why a engine may retired from a particular application but be perfectly suitable for a street car/play toy for many years in the future. At the least, it may be a perfectly suitable core for a rebuild project (if that's Dacksoldier's intent).
EDIT: Dacksoldier should certainly be aware that the engine might be tired/worn out, but if this guy is truly a friend he should be pretty well informed about the situation and have some idea about the condition of the engine.
Last edited by dstaley; Sep 11, 2008 at 12:22 PM. Reason: Added additional comment
Old Sep 11, 2008 | 12:53 PM
1980 blue L48's Avatar
1980 blue L48
I did not know that the heads were different, in the 78s?
Old Sep 11, 2008 | 10:57 PM
martinsw's Avatar
martinsw
Just keep your L48 matching number block and put on different heads, cam, intake and headers / dual exhaust. You can get to good hp numbers and still have your 'l48' block between the motor mounts. You can keep your take offs to return back to stock if, and when, ever desired.
A few years ago I wanted more power from my stock L48 1979 - ended up putting in an LS1 and T56 and have never regretted it. I was on the fence though to just keep my L48 block and rebuild with crank, rods, pistons, cam, heads (would've been less expensive and not taken as long)....not entired sure why, but still have the numbers matching L48 and TH350 in the shed (seriuosly doubt they will ever get back in their original home)
Old Sep 12, 2008 | 09:26 AM
jakesindy's Avatar
jakesindy
78 L48 and L82 head casting #,s are the same
Old Sep 12, 2008 | 10:29 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
All I did was swapped Cam ,intake, true dual exhaust, recurved distributor, on my L-48 and on the dyno I pulled 221 hp at the wheels .This was cheap and quick to do , and cheap too! Ron
Old Sep 12, 2008 | 04:25 PM
68FireBird's Avatar
68FireBird
Ron,
Which cam and intake did you use? Did you upgrade to headers?
I'm thinking about the same approach with my stock 76 L82
Old Sep 12, 2008 | 06:40 PM
Scott Marzahl
68Firebird,
Regarding your plan for the XE-262 cam and keeping your existing valve springs. You will need to call Pioneer and verify the spring rate with them, but I will venture to say that you will need to run the Comp Cams matching springs. Pioneer calls the RV-943-4 a .490" Z-28 spring and I do not see a spring rate for them. The Comp XE Cams require the use of a pretty stout spring due to their fast ramp rates. These are Comp 981-16 which are rated at 370 pounds/inch. The GM Z-28 and off-road springs are around the 300-325 pounds/inch rate.
To L48 vs. L82
377's Avatar
377
I have a 73 L-82 it has a steel crank/x rods/forged flat top 2 valve releif pistons /4 bolt block 6 qt oil pan trap door/windage tray and the cam is the 350 350 hp . head are 202 valves /guild plates/screw in studs. basically its a lt1 with less compression and a hydraulic cam. its a #matching car. but yes you can make the same or more power no problem. hope this helps
Old Sep 12, 2008 | 06:44 PM
dstaley's Avatar
dstaley
What did it come with stock?
Old Sep 24, 2008 | 07:57 PM
377's Avatar
377
thats the stock untouched # matching engine
