Shifter Install - Can't get factory bracket out..Help
Old Sep 10, 2008 | 09:29 PM
Billy Baroo's Avatar
Billy Baroo
Default Shifter Install - Can't get factory bracket out..Help
I'll try this thread with a more accurate title.
I'm putting in a Hurst shifter and I'm having trouble getting out the factory shifter bracket. I have the old shifter out and the bracket un-bolted but I can't maneuver it out. From what I have read you can move the rear of the transmission to gain clearance, but when I try and jack it up the whole car begins to move upward. I'm afraid to put too much pressure on it (just a couple of pumps on the jack); I don't want to damage the transmission. I took out the two bolts that connect the transmission to the cross-member. Am I forgetting anything?
This is frustrating; I'm so close to getting the Hurst in and I hit this lame road block. Any help would be greatly appreciated.
Thanks, Andy
Old Sep 11, 2008 | 09:08 AM
jpatrick636's Avatar
jpatrick636
The only interferance I have is the exhaust. What is interfering with the removal?
Old Sep 11, 2008 | 09:37 AM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
Remove the U bolts holding the exhaust to the exhaust bracket. Just removing the 2 mount bolts isn't enough. If the U bolts are still attached, you are basically jacking up the whole car.
Old Sep 15, 2008 | 11:20 PM
Billy Baroo
Thanks guys. You were right; it was the exhaust u-bolts. I removed them and the transmission jacked right up!! The hurst has to be one of the best additions to my car.
Andy
Old Sep 16, 2008 | 12:31 AM
Go Vette Go
Andy
I have to agree with you. I was so happy with the Hurst shifter in my 76, I installed Hurst shifters in my 69 & 78 Vettes. Sure gives you a more solid feel & shift.
John
To Shifter Install - Can't get factory bracket out..Help
