pcv line dripping gas
Old Sep 14, 2008 | 10:09 PM
77 zz4's Avatar
77 zz4
Default pcv line dripping gas
The line from my carb to the pcv valve was dripping gas near the carb. I pushed it in and it seemed to stop the drips,but it really didn't move in too much. Why would this happen?
Old Sep 14, 2008 | 11:02 PM
7T1vette's Avatar
7T1vette
Maybe the PCV isn't functional. It could be 'crudded up' so that it won't close off [when it should]. Remove it, soak it in a strong cleaner, rinse, dry...then blow through it to see that it passes air in one direction [and seals off in the other]. If there is any question, replace it; they're inexpensive.
Old Sep 15, 2008 | 02:39 AM
baxsom's Avatar
baxsom
please forgive my ignorance but how can raw gas get to the pcv?
i thought that was to vent the top of the engine of any pressure.
i have seen them drip oil but i cant figure out where the raw fuel would come from unless it is leaking from the carb somehow and going the wrong way through the hose.
Old Sep 15, 2008 | 03:46 AM
71406's Avatar
71406
I just wonder if you have your hose for the PCV connected to the wrong place. Can you show a photo of your set-up. I agree with the above post, you should not get gas coming from the line.
Old Sep 15, 2008 | 04:52 AM
SH-60B's Avatar
SH-60B
It could be an external carb leak from a gasket (or a crack?) that's running onto the PCV hose.
Old Sep 15, 2008 | 09:44 AM
77 zz4's Avatar
77 zz4
I'll try to get a pic. The line is connected to the rear port of the carb for the last 3 years w/o a problem.
Old Sep 15, 2008 | 10:08 AM
7T1vette's Avatar
7T1vette
That valve is intended for "one-way" operation. If crankcase pressure is positive, the blowby is directed to the base of the carb for injestion of hydrocarbon gasses. If it happens to be a negative pressure (sucking from the carb), the valve is supposed to seal off. Hence my question about the valve being "stuck". So...is it?
Old Sep 15, 2008 | 12:32 PM
77 zz4's Avatar
77 zz4
I don't know if it is stuck but I am going to buy a new one just in case.
Old Sep 15, 2008 | 12:46 PM
1nicecorvette's Avatar
1nicecorvette
my thoughts too
Old Sep 15, 2008 | 01:38 PM
77 zz4's Avatar
77 zz4
How do I check for that?
"It could be an external carb leak from a gasket (or a crack?) that's running onto the PCV hose."
Old Sep 15, 2008 | 02:23 PM
SH-60B's Avatar
SH-60B
Look closely at the two main gaskets, the throttle plate to bowl (lower one) and the bowl to airhorn (upper). Look for gas leaks anywhere out of the carb. Clean it up to see better. How does the motor run? Any black sooty smoke from the tail pipes?
Old Sep 15, 2008 | 02:33 PM
1nicecorvette
you should also see "wet" spots at the base of where the fuel line enters the carb.
Old Sep 15, 2008 | 02:41 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
For what it's worth, the pcv hose on all 3 of my Vettes connects to the front of the carb, the rear hose goes to the power brake booster.
Take the air cleaner off and make sure all of the screws and bolts/nuts on the top of the carb are tight. There are 4 - 1/2' that bolt the carb to the manifold - 2 in front on top & 2 on the rear. There are 5 slotted screws, 4 in the rear on top & one in front.
I just pulled the air cleaner off my 76 & checked mine - all 4 slotted screws were loose.
Old Sep 15, 2008 | 10:48 PM
1nicecorvette
yes thats true mine too is connected in front. 1979
Old Sep 15, 2008 | 10:57 PM
71406's Avatar
71406
oh, and one more thing, if you have gas dripping I would not drive the car until you fix the leak.
Old Sep 16, 2008 | 02:12 AM
Enersis's Avatar
Enersis
Originally Posted by 1nicecorvette
my thoughts too
To pcv line dripping gas
