backfire thru carb
Old Sep 14, 2008 | 07:44 PM
ripforrey's Avatar
ripforrey
Default backfire thru carb
I have a backfire (all the time) thru the carb (CarterAFB)in 76. Rotor, cap, wires all new, new plugs installed, comp check all good. Checked vacumm at EGR and vac adv. at dist. No vacuum, The vacuum comes from the front of the eng. something called an EGR TVS. Anybody know how to check and replace? Other thouhgts?
Old Sep 14, 2008 | 08:04 PM
Bobz08C6's Avatar
Bobz08C6
You could have a serious timing issue. Either the distributor is misindexed badly or set way way off or your timing chain has slipped a few teeth.
Sounds like the firing is taking place when the intake valve is open maybe.
Old Sep 14, 2008 | 08:07 PM
tfi racing's Avatar
tfi racing
Sounds like a broken rocker arm or worse, a wiped cam lobe.Pull off the covers,chances are you'll see it right away.
Old Sep 14, 2008 | 09:00 PM
stingr69's Avatar
stingr69
Time to pull the valve covers off.
-Mark.
Old Sep 15, 2008 | 07:37 AM
Matt Gruber's Avatar
Matt Gruber
maybe a friend swapped plug wires as a joke.
Old Sep 15, 2008 | 06:15 PM
c31980's Avatar
c31980
check the firing order
Old Sep 15, 2008 | 07:40 PM
SH-60B's Avatar
SH-60B
I had the same symptoms on mine. 3 cam lobes were pretty much gone.
Old Sep 15, 2008 | 07:45 PM
thegazman's Avatar
thegazman
Default thegazman
Ripforrey....When you find the problem let us know. These guys could be right as you will still have compression with worn cam lobes.
Old Sep 15, 2008 | 11:00 PM
nekkutter's Avatar
nekkutter
yup... I agree with tfi racing, My Z28 was doing the same a few yrs. ago
Old Sep 16, 2008 | 02:13 AM
Enersis's Avatar
Enersis
thats what mine was, rofl
To backfire thru carb
