Challenging orthodoxy
Old Sep 11, 2008 | 02:06 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Challenging orthodoxy
So I get frustrated reading car magazines and the forums. It appears that they all want to do the same thing, and nothing ever gets challenged.
So I want to go WAY out into the weeds and do something strange.
I want to build a hot rod motor that does not contain AFR cylinderheads, an Edelbrock intake, or a Comp cams cam. Now I read a healthy portion of Tony's posts and is more than likely a good guy, but I really dont want to use his product for purely illogical reasons.
So what I am thinking is a 355ci motor, forged crankshaft, I have some used billet rods, and maybe a decent set of flat top pistons. (the new LS7 has hyper pistons and a 4" stroke turning 7000rpms)
So I am thinking Dart Iron Eagle 200s (have you seen the flow on these 288cfm out of the box at .5 lift ) with 64cc chambers.
Crane cams 222/230(112 LSA 107ICL) OE Hydraulic Roller Cam (284/292 112 LSA 111ICL).
1.6 ratio roller rockers
Hooker sidemounts
Should be fun!
The goal is 460hp and this should more than meet the goal.
Hell a ZZ430 with a hotcam should get there too. But that's just scandalous.
I have no idea about induction, I am leaning towards a weiand Team G with a barry grant vacuum secondary 750cfm speed demon with annular boosters would be suitably out there.
Old Sep 11, 2008 | 02:23 PM
Guru_4_hire
Cruise-In V Veteran
http://users.erols.com/srweiss/tablehdc.htm
Dart iron eagle 200 Platinum
.2 130/109
.3 194/158
.4 242/198
.5 274/208
.6 283/214
AFR 195 Eliminator (2000-6500 rpm supposedly)
.2 137/110
.3 194/158
.4 240/190
.5 270/207
.6 286/215
Just for fun.
