Vortec Crack
Old Sep 12, 2008 | 08:27 PM
bytor's Avatar
bytor
Default Vortec Crack
Took my used Vortec heads to a local machine shop today to have them cleaned and pressure checked. The guy at the shop said that the Vortec heads are prone for cracks around one on the center head bolt holes.
Cracked Head
Sure enough, he did a quick mag flux while I was there and both of mine had a small hairline crack. It's repairable and and isn't that big of a deal if its caught early enough.
Has anyone else had this problem?
Old Sep 12, 2008 | 08:30 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Notorious problem. Not the first I have heard of it.
The Bowtie small port would probably right up your alley.
Old Sep 12, 2008 | 09:03 PM
slapshot 496's Avatar
slapshot 496
The VORTECS are a great head for making power and really wake up a 327-350 however longjevity is a serious issue..Very prone to cracking!!!!!!
Old Sep 12, 2008 | 09:15 PM
billla's Avatar
billla
St. Jude Donor '14
Can you post the casting number?
This is why I generally suggest just buying new - cheaper
Old Sep 12, 2008 | 09:17 PM
bytor's Avatar
bytor
Casting# 10239906
Old Sep 13, 2008 | 09:39 AM
Durango_Boy's Avatar
Durango_Boy
So far I have had four sets of Vortec heads Magnafluxed and no cracks were found. Ranging from '96 to '99.
Old Sep 13, 2008 | 10:09 AM
L88Plus's Avatar
L88Plus
I've handled several used sets and the only ones I've seen that were cracked were overheated pretty badly, I haven't found a single cracked head that came off of a running engine.
Old Sep 13, 2008 | 03:06 PM
hotrodrik's Avatar
hotrodrik
Default vortec cracks
I had a set i had to pull off of a car , coolant in the oil , one head cracked.. only buy them new
Old Sep 13, 2008 | 03:13 PM
Project80's Avatar
Project80
Originally Posted by bytor
Casting# 10239906
"For you junkyard hunters, be forewarned that some ¾- and 1-ton trucks came with Vortec heads equipped with a specially hardened exhaust seat that kills low- and mid-lift flow. Casting number 10239906 should be avoided"
This info came from a magazine article about Vortecs.
http://www.chevyhiperformance.com/ho...458/index.html
To Vortec Crack
