Today I decided to drive the vette out to a nearby car wash place, I've noticed that the engine heat is a little more than usual (210-215) so I thought maybe the coolant level is low, as I didn't drive it for the last 2 months. when I got back home, I let it cool then I noticed that the level is indeed low, I started the engine and started to add coolant, I noticed that after the engine got a little warm, the coolant started to be VERY foamy and started to over flow all over the place!!! .. I smelled it and it didn't have any oil smell in it. I closed the cap and its still overheating (maybe worst that before!!) .. what do you think the problem is??? My car is a '71 big block with Dewitt's radiator and dual spal fans, I'm using a %100 distilled water + two cans of 40* below additive.
..... I've noticed that the engine heat is a little more than usual (210-215) so I thought maybe the coolant level is low, as I didn't drive it for the last 2 months. when I got back home, I let it cool then I noticed that the level is indeed low, I started the engine and started to add coolant, I noticed that after the engine got a little warm, the coolant started to be VERY foamy and started to over flow all over the place!!! ..
Do you think I may have a bad head gaskets???
Unfortunately, foamy coolant in the radiator is a reasonably good indicator of emulsified oil.
Fill your cooling system with water to the neck of the filler cap when motor is cold, and check for bubbles after starting it.
Assuming that block water jackets are filled, any bubbles appearing will verify that it's a blown head gasket, releasing combustible gaspressure into cooling system.
If it's an automatic, verify that the transmission cooler has not failed. Look for coolant in the trans fluid. It it is, you will probably have to rebuild it as the water attacks the glue that holds the clutch facings on.
It could also be that there is a small leak in the water pump intake area and it is pumping air into the system. Unlikely, but possible. Tighten all the water pump bolts and hose clamps, just to be sure.
a lot of those additives (ie redlines water wetter) have corrosion fighting and lubrication properties built into them.
also, i know i thought i had a bad head gasket on a car once and the mechanic tested it by filling a tube looking thing with this yellow liquid and mixing it with a sample of coolant. he said any hydrocarbons in the coolant will turn the yellow liquid black.
cant remember the name of the stuff though but supposedly it was a fool proof way to know for sure.
That is the best test for exhaust in the coolant.
Do all you other tests first, but be aware that if you did not use exactly the same brand of additive each time, these days it can cause foaming. Another good reason is to empty, rinse and refilf yearly.
