74 radiator
Pull the hood, pull fan, remove hoses from wtr pump & top hose, take all 6 bolts out of the sides of the radiator support & loosen up the 2 supports on the bottom. remove support bar on center of rad support. pull top of radiator & support as far forward as possible. With the original shroud this will give you JUST barely enough room to pull out the shroud. after that pull rad clamps, and pull the rad. This is much, much easier with another person to help lift the rad. It is a straightforward job, just a pita with the original shroud.
That is the proper procedure. People try various shotcuts and then claim there is no way to get the rad out without cutting the shroud in half.
Regards,
Alan
