suspension package
They also have the Street and Slalom kit which has the 550# coils in the front and 360# rear spring and this kit includes their redesigned bracket. This package will give you a little more of a performance feel and is suitable for some light racing and fun track days.
If you need to do a total suspension upgrade, the Performance Plus Kit is the way to go because it includes all new control arm bushings, ball joints, tie rod ends, offset upper cross shafts for the control arms and new lowers, front and rear shim kits, a crossmember reinforcing kit to help from frame damage with the upgraded suspension, diff. bushing, trailing arm bushings, etc. You get their redesigned control arms with the uppers having the ball joint relocated for added camber/castor and the offset cross shafts. They all come preassembled so you can just bolt the arms right in. You will receive their poly that is still hand poured to their specs with graphite impregnated to give you better, quicker reaction at the pivot points. For the price, you can upgrade your complete suspension and receive all the parts you need except the shock mounts which can be re-used or purchased separately.
Both the front and rear spring systems in the performance plus package allow you to adjust the spring rate as well as the ride height. This gives you the most versatility as you can set it up for a cross country touring ride or jack her up, make some adjustments and have a fun day at the track. It gives you the best of the best they have to offer and the opportunity to have different ride qualities to get the most out of driving your Corvette on the street or some fun track days.
If you have any questions and would like to discuss their packages further, please do not hesitate to private message me, email me directly at pattiesattic@tampabay.rr.com or call Steve and Gary in the tech dept. at 1-800-237-9991.
Best Regards,
Pattie
Tom
Let me know how you like it after the install.
