Where's the Ground???
Old Sep 16, 2008 | 09:49 PM
pspeck's Avatar
pspeck
2nd Gear
Default Where's the Ground???
Hello all!! I am Paul a newbie corvette owner from flint MI.
My corvette is a 1976 Stingray L48 which sat for 17 years in my Uncles dirt Floor garage. I know I can hear the sighs. Anyway I was "lUCKY" to get it in a swap. I built a new garage 4 him and i got the Vette. I have limited car knowledge but consider myself fairly capabable of most jobs given they do not require specialty tools. I started out changing the front wheel bearings and replacing the Rotors and Calipers. After getting it on the road to test I found that my U joints and rear bearings were shot........$3000 later I am back on the road Thanks to Bairs Corvette in Penn. (Great work!!!!!!!!!!) My problem now is that I do not have Strong rear lights, NO blinkers and my fuel gage flips to full every time I hit the brakes. I have re attached two grounds on the rear frame but still have the same problems. Can anyone suggest an area to look for hidden grounds or a "Master ground/Harness" that could be causing the problem???? Oh Yeah My tach is stuck at 3100. Ground also????
Thanks in advance for any responses!!!!
pspeck
Old Sep 16, 2008 | 10:25 PM
Corellian Corvette's Avatar
Corellian Corvette
I can only be partially helpful.
The TACH is mechanical - meaning there is an actual gear on the distributor that uses a "speedometer" like cable and connects to the back of the tach housing. It's not a really hard job to replace the cable. Just make sure you re-clock your distributor to the 9 o'clock position (if looking from above). This makes the cable easier to install and last longer.
You might want to check ground at the battery cable for the beginning of your ground search. That cable connects to the frame right under the battery tray. More than likely you have a loose ground or a loose connection on the back of your gauge cluster causing the problem. Get yourself a good wiring diagram (many vendors sell them laminated) and invest in the factory service manual or a reproduction! It's great to have!
Old Sep 16, 2008 | 10:36 PM
DC3's Avatar
DC3
Tach on a '76 is electric. They started that in '75 due to the new HEI ignition.
DC
Old Sep 16, 2008 | 10:54 PM
CCrane65's Avatar
CCrane65
pspeck
Every taillight has it's own ground connector but they are wired together. Fix the ground problems before attempting the turn signals.
Always remember that Corvette bodies are fiberglass therefore no body ground. Every electrical item needs a ground wire.
For the turn signals start with the flasher which is under the passenger lower dash pad. Also check the fuse panel which is way up under the dash in the upper left corner of the driver side on the firewall.
Your gas gauge is also likely to be a ground problem from the description you gave.
Afraid I can't help with the tach.
cc
Old Sep 17, 2008 | 01:25 AM
7T1vette's Avatar
7T1vette
A 'metal' bodied car is 'grounded' everywhere because the frame and body are all electrically linked. The Corvette is a plastic body (non-conducting) with a metal frame; so 'ground' is transfered differently than most cars. Generally, there are frame-linked ground cables which connect electrical ground to the different areas of the car (to engine, to starter, to interior, etc.). From those points, there are solid black colored wiring that runs ground to all individual point requiring them (lights, instruments, radio, lighter, etc.). You need to purchase an Assembly Instruction Manual (known as the AIM) for your year Corvette. It shows all of the grounding cable locations. You also need an electrical schematic for your car; I like the Chevrolet Chassis Service Manual (year specific). Most Corvette parts places have both.
Old Sep 17, 2008 | 05:12 AM
BenUK's Avatar
BenUK
I think I counted four earthing points between body and chassis when I took the body off my '76.
1.
Main battery earth under the battery near the diff. (If this is bad then nothing should work.)
2.
Main starter motor/engine earth between engine block and passenger-side engine support chassis bracket. (Bad earth here means engine wouldn't start, no headlights, no wipers etc.)
3.
Small earth lead from driver's side #1 body mount to chassis, just behind the front wheel:
4.
Larger earth for rear lights, aerial, gas tank etc. right at the rear of the chassis on the driver's side:
My guess is that the rear earth is dodgy.
When I bought my car the tach was also stuck. In my case it was simply because the tach wire wasn't plugged in to the distributor. Since then it's worked fine. If your problem isn't that then you might need a new tach circuit board.
Old Sep 17, 2008 | 09:37 AM
hugie82's Avatar
hugie82
Missed a couple more grounds. My 74 had a gound on the pass side engine mount to frame and one on the driver side seat belt bolt under the floor board going to the frame.
Old Sep 17, 2008 | 10:51 AM
BenUK's Avatar
BenUK
Weird - my '76 didn't have the seatbelt earthing point.
The pass side engine mount is my number 2 above.
Old Mar 15, 2013 | 05:56 PM
Msp1953's Avatar
Msp1953
6th Gear
I also have a grounding problem on my 76 corvette.. I have checked the rear grounding point and it seems fine...My turn signals do not blink......new flasher..but when I turn on my left signal, my console light comes on.........................Help......... ...is there another ground point on the rear that I am missing?????????????????????
Old Mar 15, 2013 | 07:21 PM
roscobbc's Avatar
roscobbc
Black Wire Disease was a problem with model aircraft radio control equipment that used to affect the copper stranded cable feeding the servos - whilst the cable is intact the internal resistance once 'black wire' had set-in was sufficient that the servos wouldn't function. I was surprised when the earth tails from rear lamps to chassis on my '68 (when I first got it) had exactly the same problem - only after replacing the tails and opening them-up the could you see the corrosion - the copper was almost crystaline!
Old Mar 15, 2013 | 08:35 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi and welcome!
See post 7 to check if the socket has a good ground.
http://forums.corvetteforum.com/c3-g...n-signals.html
Here's a schematic.
http://www.vetteprojects.com/bmv/mis...tte%201976.pdf
See if this helps a little.
Old Mar 16, 2013 | 10:32 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...I am...a newbie...
Order an owner's manual if you do not have one.
Order the assembly instruction manual (AIM) for 76. The AIM shows all of the factory grounding points.
Old Mar 16, 2013 | 11:37 AM
Msp1953's Avatar
Msp1953
6th Gear
Thank You for all the great information.....I will try running a temp ground and see if that cures my problems.....Thanks Again
Old Mar 16, 2013 | 05:34 PM
Peterbuilt's Avatar
Peterbuilt
Default While your at it...
Check that the bulbs are all 1157 and inserted correctly.
Old Mar 16, 2013 | 08:55 PM
hugie82's Avatar
hugie82
Electric gremlins suck and you must have been looking for awhile to pull this thread up from 5 years ago.
I would check the head light switch after all your sockets are checked.
There is also a wire harness bend located behind the front drivers side head light that is know to have wires breaking and shorting problem. Not sure if its all C3 but I know my 82 needs a wiggle every now and then. One day I'll fix it hopefully before I burn it to the ground
Old Mar 17, 2013 | 12:13 PM
lvmyvt76's Avatar
lvmyvt76
have you checked for 12volts at the lights?? If no 12 volts, then grounding won't help. Need to see if 12 volts are present, then check for grounding problems.
To Where's the Ground???
