Steering wheel doesn't return to center
Old Sep 17, 2008 | 05:21 PM
DVagedes's Avatar
DVagedes
Default Steering wheel doesn't return to center
I have thought that the steering on my '76 seemed a little too touchy...and after letting a couple other people drive it we have decided that it is because my steering does not return to center while driving.
It has a new power steering valve, and I am pretty sure that I adjusted it correctly. It doesn't pull to one side or the other, it just stays exactly where you put it.
Is is supposed to be this way?
Old Sep 17, 2008 | 05:50 PM
BenUK's Avatar
BenUK
I could be wrong, but I thought the geometry of the front suspension dictated how strongly the wheel was self-centering. It's connected to the caster of the front wheels. If you have zero caster then your steering will be lighter but won't self-centre.
(Caster is a measurement of how vertical the wheels' steering axis is.)
When you turn your steering to full lock (in either direction) do the front wheels lean in or out at all?
Old Sep 17, 2008 | 06:03 PM
7T1vette's Avatar
7T1vette
You may have some damage/wear in the steering gear box, so that there is some drag which prevents the steering from returning to center. There might be some adjustment with the power steering somewhere for this, but I am not familiar enough with that to know.
Old Sep 17, 2008 | 06:21 PM
GTR1999's Avatar
GTR1999
If the alignment is off that will be a problem. If the box is worn it will be sloppy on center- is it? I'd relook at the control valve, if it's rebuilt one then it's a crap shoot on quality.
Old Sep 26, 2008 | 12:55 PM
DVagedes's Avatar
DVagedes
Yes, it is a rebuilt valve, but it seems to work fine and be adjusted correctly. Steering is not particularly sloppy from center, other than the fact that it doesn't self-center like it should.
This seems to be a tough problem to fix on my own since any adjustment in one area throws off the adjustment of another.
Plus there is a LOT of slop in my trailing arms, which I am sure does not help anything. I had a 4 wheel alignment done (well....paid for)
Any body know a good alignment shop in the Sidney/Dayton Ohio area?
Old Sep 26, 2008 | 01:30 PM
reelthing's Avatar
reelthing
I had the same problem when I replaced my steering valve. I was able to correct by taking off the steering valve and reposition by adjusting the number of turns
Old Sep 29, 2008 | 02:26 PM
WillEE's Avatar
WillEE
I'm fairly new to vetts but would the "steering valve" be the part that looks like a shock absorber under the driver's side or would it be the box next to it that the hoses go into? (I realize it's not gearbox or ps pump).
I've noticed that my '82 doesn't want to return all the way to center either - maybe spins about 75% on it's own and the rest you have to manually bring back. Can you please elaborate a little more on what you took off and what you turned/adjusted and which direction? I would greatly appreciate knowing a little more about what you did.
Old Sep 30, 2008 | 08:04 AM
reelthing's Avatar
reelthing
No, that is the assist steering cylinder; follow this link for pic of steering control valve. http://www.ecklers.com/product.asp?p...5&dept_id=1829
When you replace the valve, you have to count the number of turns CCW that it took to remove from the threaded tie rod. When you replace the valve and put on, turn it CW the same number of turns. This is where I screwed up initially on my installation. My wheel was not centered so after a few adjustments as I described, it worked. Not to be confused with the steering valve adjustment nut that is located on the steering valve. That process is to balance the valve itself with the car jacked up and wheels off.
To Steering wheel doesn't return to center
