Compression Ratio
Old Sep 17, 2008 | 07:47 PM
Oldguard 7's Avatar
Oldguard 7
Default Compression Ratio
Can someone calculate the static compression ratio of my engine? Here is some info on my engine.
350ci +.060.
L-82 style forged pistons +.060
Deck Height: 0.00
Edelbrock RPM aluminum heads
Combustion Chamber Volume: 64cc
Not sure of the piston volume from the bottom to the top of the cylinder.
I'm thinking my static is 10.00:1 or more due to the increased bore of the cylinders and the 64cc heads. I don't know how to use the calculators on the websites. I would appreciate if someone would do so. Thanks in advance.
Old Sep 17, 2008 | 09:30 PM
Scott Marzahl's Avatar
Scott Marzahl
To have zero deck height you would have had to had the block decked, is that really what you have. Typically a stock deck height is .025", that is the top of the piston is .025" below the deck. Also what head gasket are you using? What is the piston P/N, are they the direct L-82 flat top replacements?
Old Sep 17, 2008 | 09:33 PM
weimer20's Avatar
weimer20
I would bet you are over 10 - 1 as well but more info is needed to calculate the ratio. Valve relief cc info, head gasket bore and compressed thickness, etc.
Old Sep 17, 2008 | 10:46 PM
Oldguard 7's Avatar
Oldguard 7
The pistons are TRW #L2417 forged flattop with a single trough valve relief w/floating pins (.060 oversize). The head gaskets are Fel-Pro #20003. As far as the deck height goes, you are probably right. I will have to look at the engine spec sheet which is part of a packet about everything about my model year I got from GM a few years ago. I am pulling this off the top of my head, if i'm wrong, I will get the correct part numbers. The pistons are direct TRW replacements though. I hope this will help.
Old Sep 17, 2008 | 11:53 PM
stingr69's Avatar
stingr69
I made some assumptions:
.039" gaskets
.025" deck
-5cc trough
I come up with 9.9:1
-Mark.
Old Sep 18, 2008 | 03:19 AM
jackson's Avatar
jackson
My TRW-FM-SP book says L2417F60 = 1.560" cd, -3.4cc dv
add ABOUT 1.7cc to volume for chamfer & land
assume stock uncut deck ~ 9.025" and typical comp gasket ~ 9cc ... scr ABOUT 9.85:1
You might as well call it ten to one
TRW-SP-FederalMogul scr calculator:
http://www.21cgt.com/FMWebCatalog/frmConversion4.aspx
To Compression Ratio
