Compression Test Results LT-1
Old Sep 18, 2008 | 03:16 PM
wallifishrmn's Avatar
wallifishrmn
Default Compression Test Results LT-1
Had a compression test done at a local shop and it turned out the valve seals were bad--had them replaced. My question is when the mechanic gave me the compression test results the numbers seemed high compared to the compression test results I have seen listed by other forum members. Here are the numbers--do they seem high or is this normal for a 71 LT-1? Car runs great now that the but was loosing oil via the valve seals.
#1 185
#2 190
#3 180
#4 190
#5 175
#6 175
#7 185
#8 190
Old Sep 18, 2008 | 03:45 PM
7T1vette's Avatar
7T1vette
Per the Chevrolet Service Manual, cylinder compression for 1971 LT1 engine should be 150 psi (with no more than 20 psi variation between all eight cylinders). The 'method' of measuring engine compression might be different between your mechanic and GM. Your readings are consistent...which is a good thing.
Old Sep 18, 2008 | 04:33 PM
DC3's Avatar
DC3
Your mechanic's gauge could be reading high but the consistency of the readings between cylinders is indicative of a healthy engine. You might check a cylinder or two with a gauge of known calibration.
DC
Old Sep 18, 2008 | 11:01 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
I have a 186 headed small block with the 224@050 lift cam. My numbers run 190's just like yours. Ron B.
Old Sep 19, 2008 | 01:05 AM
Solid LT1's Avatar
Solid LT1
I use a cylinder leakdown tester (pressurized guage using air compressor) that is much more accurate than cranking compression for determining cylinder leakage. Numbers seem high and too consistant unless engine has low mileage on it (did he really do a leakdown test of all 8 cylinders?) You should go to umbrella type guide seals for a Ford 289 motor instead of the poor design of the Chevy "O" rings.
Old Sep 19, 2008 | 08:10 AM
7T1vette's Avatar
7T1vette
The compression numbers don't tell us anything about a 'leakdown' test, so I'm guessing one hasn't been done...just the 'cranking' compression test.
Old Sep 19, 2008 | 08:18 AM
...Roger...'s Avatar
...Roger...
Carbon build up will cause compression to go up.
To Compression Test Results LT-1
