Odd noise from car
Old Sep 19, 2008 | 10:52 PM
canamer757's Avatar
canamer757
1st Gear
Default Odd noise from car
I am having trouble finding a noise. When you rev it up insted of a rumble it is more of a whine , also when I go 90+mph it shakes real bad! Help!
check out the vid on you tube the link is http://www.youtube.com/watch?v=t0XL48L9rJs
just copie and paste it to the top
Old Sep 20, 2008 | 09:40 AM
schmegeggie's Avatar
schmegeggie
Could be a number of things, but I would certainly refrain from taking it up to 90+ MPH until you figure it out.
The whine could be something as simple as the alt. bearing. The shaking at 90 is more than likely something totally different like a wheel out of balance or a bad U-joint.
Old Sep 20, 2008 | 09:58 AM
AimHigh's Avatar
AimHigh
Whining could be belt related or something in the alt or p/s area.
90 mph + problem sounds like a balace issued somewhere in the driveline, (wheel balance or possible shaft prob)
At any rate I'd say it's two separate issues.
To Odd noise from car
