starter wiring
Old Sep 20, 2008 | 01:36 PM
denise84's Avatar
denise84
3rd Gear
Default starter wiring
does anyone have a picture or know how to wire the starter. My buddy's starter went bad and when it was removed he didn't look at which wire went where and they are not color coded. Any ideas? Right now the way it is connect when you hook up the battery terminals his starter starts without the keys in
Old Sep 20, 2008 | 01:47 PM
...Roger...'s Avatar
...Roger...
The wire attached to the S terminal is probably over against and touching the pos.battery cable.
edit-what year?
Old Sep 20, 2008 | 02:09 PM
denise84's Avatar
denise84
3rd Gear
Old Sep 20, 2008 | 02:17 PM
...Roger...
The purple wire with small eyelet connector goes on the S term on the solenoid.The small 14 gauge black wire with large eyelet terminal goes on a bolt grounded to the block,like a bellhousing bolt.The large battery cable and red wires all with large eyelit terminals go on the large term of solenoid.If you have another small term. on the solenoid labeled R it is not used on your 80
To starter wiring
