Everything new. And still
Old Sep 21, 2008 | 08:33 PM
Brown78's Avatar
Brown78
Default Everything new. And still
Everything new. And still I don't have a high speed fan for my heater and A/C. Only 123 speed. Even the thing with the 3 or 4 springs coils in the engine compartment on the right side. Is there a relay or something I've mist.?
Old Sep 21, 2008 | 09:01 PM
...Roger...'s Avatar
...Roger...
Yes the high speed relay.
Old Sep 22, 2008 | 02:05 AM
Peterbuilt's Avatar
Peterbuilt
Not sure about your 78 but on my 74 there is a seperate in-line fuse for A/C high speed, it's under the left fender near the master cylinder.
The relay is on the right side on the A/C unit, there are 4 wires:
Black
Yellow
Blue Red hooked it in that order. PG.
Old Sep 22, 2008 | 06:46 PM
Brown78's Avatar
Brown78
Black Yellow Blue Red hooked it in that order. PG.
That is new too. The relay is on the right side on the A/C unit, there are 4 wires: Black Yellow Blue Red hooked it in that order.
Old Sep 22, 2008 | 08:23 PM
...Roger...
Is the red wire at the relay hot at all times and is the black wire grounded?If so check to see if the orange wire is hot with the blower switch in high position and the key in the on position.Let us know.
(If you have an early production the rear window defog can knock out high blower if the defog is on.)
Old Sep 23, 2008 | 06:29 PM
Brown78's Avatar
Brown78
I have the defogger, and it works. I know when it's on the high speed fan does not work on high. Only the med/high. I would turn off the defogger and would have the high speed fan. I'll put a test light on the red and orange wire tomorrow. I'm glad I have already gone gray.
Old Sep 23, 2008 | 06:51 PM
7T1vette's Avatar
7T1vette
If your fan electric system is the same as early '70s cars, the 30 amp 'glass' fuse (bayonet mount) is located on the inner-left front fender just inside the brake master cylinder. It has a red wire coming in and an orange wire going out. It is likely bad.
Old Sep 23, 2008 | 09:52 PM
AimHigh's Avatar
AimHigh
All right guys you get to laugh at me on one but hopefully this will help our guy......when I went through my car this past spring I put in a new switch as well, and then didn't have high fan.
Well after lots of checking I took the console back apart and checked the plug in to the switch and low and behold I was slightly off and had missed a prong on the swith so that at first glance the plastic plug into the switch looked good, but on closer inspection you could see where I had missed the prong on reassembly.
Just a suggestion but it might help....
To Everything new. And still
