Headers size?
Old Sep 23, 2008 | 03:08 AM
Jonathan502's Avatar
Jonathan502
Default Headers size?
Hey!
What are the biggest size of prime tubes and collector you could have
on a 1969 whith removed ac, with a ZZ502?
Thanks..
Old Sep 23, 2008 | 07:06 AM
Rolling Thunder's Avatar
Rolling Thunder
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
My Stahl headers are 2 1/8th inch primaries.
Shown here
Old Sep 23, 2008 | 07:09 AM
Vesa's Avatar
Vesa
I have Hookers nr2225 with no problems (NO AC). 255/50/17 tires needed for enough ground clearance...
Old Sep 23, 2008 | 07:47 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Unless you're really spinning it high..solid roller etc.....a set of 1-7/8" or 2" will most likely be what you need. 2-1/8" will be a little large.
I think most of the ZZ502's require a little flange grinding to clear head bolts with the stock position ex ports....but no big deal.
I know a Forum member with a set of 2" Hookers with 3" collectors that are Jet Hot coated are for sale. I need to check to see for sure though...they might be 1-7/8"...I just saw them last week for an instant.
JIM
Old Sep 23, 2008 | 09:46 AM
Jonathan502
I was thinking of these aswell. I have 255/60-15 so the ground clearance sould be the same!
What kind of model should I choose? Coated, polished??
Old Sep 23, 2008 | 02:15 PM
Vesa's Avatar
Vesa
I have the black ones...but if I would buy them today I definitely would take the thermal coated ones!!!
My engine is 540 cid and I never rew it over 6500rpm.
Old Sep 25, 2008 | 03:00 AM
Jonathan502
I have 2" prim, and 3" collector today and I think there is no space for lagrer tubes, are you sure 2 1/8" will fit with a gen V block??
Old Sep 25, 2008 | 05:19 AM
Vesa's Avatar
Vesa
Absolutely sure...those Hookers 2225 are diffrently routed and fit better than my previous Hedmans with 2" primaries. No modifications done to 2225s but I had to do 2 dents into the Hedmans.
If you have original AC car from which all Ac stuff has been thrown away...then you need, like I had to, to modify the AC/Heater box from the bottom. That was no big job. If original no AC car then no problems at all...
http://finnshark.com/gallery/showima...&c=3&userid=22
Actually i had to remove a bit more from the box than what you see in that picture...
Old Sep 25, 2008 | 05:24 AM
Vesa's Avatar
Vesa
Some pics of my left side with Hookers 2225 on:
http://forums.corvetteforum.com/show....php?t=2138129
Old Sep 25, 2008 | 06:51 AM
Jonathan502
Ok!
tanks, I will try. and hope it works..
To Headers size?
