HEI Wire
Old Sep 23, 2008 | 04:34 PM
glo's Avatar
glo
Default HEI Wire
On my ele. wiring chart if I am seeing it right it shows pink wire and brown for hei dist. Pink is power and br is tach? I want to make sure my wiring is right.This is for 77 corvette.
Gary
Old Sep 23, 2008 | 05:50 PM
Durango_Boy's Avatar
Durango_Boy
Yep, and you can test the wires if you're confused but brown does indeed go to the tach, and pink would be your power wire. Make sure it's switched power though or the coil will always be energized.
Old Sep 23, 2008 | 08:25 PM
glo's Avatar
glo
Thanks alot,I will check switch power
Old Sep 24, 2008 | 04:08 AM
hunt4cleanair's Avatar
hunt4cleanair
Gary...I'm looking at a 78 schematic but I take it your 77 does not have a white wire as well?
To HEI Wire
