changing tach cable
Old Sep 23, 2008 | 08:40 PM
coalminer's Avatar
coalminer
8th Gear
Default changing tach cable
Having to change tach cable on 69, how do I get the dash out.
Old Sep 23, 2008 | 10:13 PM
Durango_Boy's Avatar
Durango_Boy
I know you can reach the speedometer cable from under the dash without removing it...you 'might' be able to reach the tach cable from under the dash as well, and then just feed it through the firewall grommet.
Maybe someone who has changed one will chime in, since I don't know if it clips on like the speedo cable or if it threads on like it does on the body of the tach.
Old Sep 23, 2008 | 10:20 PM
wombvette's Avatar
wombvette
Its not easy, but it can be done. I certainly wouldnt pull the dash to do it. I use a long screwdriver and push the clip down, while someone else pulls out on the cable. Going back in is fairly easy. Just guide it on and push.
Old Sep 23, 2008 | 10:24 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The 69 cable can be changed without taking the dash out of the car. It is a clip on cable which means you’ll have to push on the clip that holds the cable in place toward the back of the car to release the cable.
Collapsing the cable clip enough to release the cable can be challenging and real hard on your finger. The clip must be pushed in far enough to release the cable from the tachometer and the only way to tell is to pull forward on the cable when you think you have the clip down far enough.
Once you have the cable loose, you can pull it outward from the firewall side.
If you want to see how the dash pad comes out of the car you can find detailed instructions on our web site. I'm sure after you look at these, you'll try it from below!
http://willcoxcorvette.com/repairand...lp.php?hID=105
Willcox
Old Sep 23, 2008 | 10:36 PM
1Fordman's Avatar
1Fordman
Be glad you have a 69 with the clip on cables instead of the 68 screw on ones. At least one part of cable replacement is a bit easier on yours!
Old Sep 24, 2008 | 09:12 PM
coalminer's Avatar
coalminer
8th Gear
Just got the tach cable in the vette, from under the dash, glad i hit this forum last night, really want to thank everyone's help. Really saved me some time & work.
Thanks again.
Old Sep 25, 2008 | 07:52 PM
BrentDev's Avatar
BrentDev
Very timely!!!! This is my Columbus Day project -- I'm off, but the kids are in school.
How long did this take you?
Old Sep 26, 2008 | 08:41 AM
coalminer's Avatar
coalminer
8th Gear
TOOK ABOUT AN HOUR & HALF, WASN'T IN ANY HURRY, WANTED TO BE CAREFUL REACHING UNDER THE DASH NOT TO PULL ANY WIRES LOOSE, EVERYTHING WORKS RIGHT NOW, EVEN THE CLOCK, BEST TO HAVE SOMEONE HELP, LIKE ON E THE POSTS SAID, I HAD THE WIFE PULL ON THE CABLE FROM THE ENGINE COMP. WHILE I PUSHON ON THE CLIP THAT HOLDS THE CABLE IN THE TACH.
GOOD LUCK ON YOURS,
BILL...
Old Sep 26, 2008 | 08:44 AM
Durango_Boy
Thanks again.
I'm sure I can speak for everyone...you're very welcome.
To changing tach cable
