Amp gauge
Old Sep 24, 2008 | 11:53 AM
captanpants's Avatar
captanpants
Default Amp gauge
I just removed my gauge cluster and the Amp gauge was not hooked up after engine was pulled. I'm not sure how to run new wires to the gauge .The wires were clipped somewhere in the harness. Thank's for all the help lately. A new EGR cover helped my rough cruising problem some, but still getting back fire on rt. bank when i back off.
Old Sep 24, 2008 | 12:02 PM
SIXFOOTER's Avatar
SIXFOOTER
see if this helps. I took a 3 page schematic and cut it down so all thats left is the charging and meter circuit
Old Sep 24, 2008 | 12:11 PM
7T1vette's Avatar
7T1vette
The C3 amp gauge displays "AMPS", but does NOT read amps directly. It is really a millivolt meter which reads the 'voltage drop' across a specific length of wire in the C3 wiring harness [that wire DOES have the car's current draw running through it]. That length of wire acts like a "shunt" resistor and creates a voltage drop (proportional to the current flowing in it) which the meter then displays on an "AMPS" scale. You can test the meter by touching the leads from a 1.5v battery to the meter leads just for an instant so you can see if the meter needle moves. [note; if the needle moves the wrong way, reverse the leads] Basically, if the meter moves at all, it is likely OK to use. I don't have knowledge of the exact length & size of the wire used as a "shunt" inside the wiring harness; perhaps someone else on the Forum can supply that into. There are other ways to calibrate the meter to your car's system, if you have an amp reading multi-meter. If you send me a PM, we can discuss it.
Old Sep 24, 2008 | 01:04 PM
captanpants
Default Amp gauge
From what i have been reading i think i wll maybe try and find a volt gauge for the old 73. I bought a aftermarket amp gauge and the instructions looked like a nice fire.
Old Sep 24, 2008 | 01:53 PM
SH-60B's Avatar
SH-60B
I don't blame you. I guess that's an external shunt on that gage. The really old Chevys had an internal shunt. The volt gage is simpler to install (and understand).
Old Sep 24, 2008 | 03:33 PM
captanpants
Thank's guy's i just got back from AUTOZONE w/new volt gauge it look's pretty good in the hole!!!!
To Amp gauge
