69 mystery
Old Sep 24, 2008 | 03:03 PM
bluestinger's Avatar
bluestinger
Navigator
Default 69 mystery
I have a 69 smallblock sidepipe auto. The car had 27,000 miles on it when I got it. I am the third owner and know where it has been. The car had been sitting sence the late seventies when I got it... It did not have one missing screw. The mystery is it has no reverse lights. The lenses are all red with no clear centers. There is a reverse switch at the shifter, but nothing happens when put in reverse. All the fiberoptics work... The car was built in eraly 1970 and has 1970 front markerlights...
Any clues???????
Old Sep 24, 2008 | 03:17 PM
Garys 68's Avatar
Garys 68
It has 68 lenses.
68s had all red lenses and reverse lights under the bumpers (one year only).
Old Sep 24, 2008 | 03:33 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Originally Posted by Garys 68
It has 68 lenses.
ether 68 lense or an extra pair of 69's or later
previous owner mod to get the Quad tail light look. Do all four light up? if so you sould see evidence of some splicing in the rear harness and some hangiong or cut wires for the reverse lights
Hint: back in the day the car year could be told by looking at the year on the lenses themselves if original, take a peek and see what you see
Old Sep 24, 2008 | 03:42 PM
RPOL68's Avatar
RPOL68
If it was built in early 70 it is a 1970 model. Why do you think it's a 1969? You also didn't say if the inner set of lights illuminates at all.
You don't know what has been done to it until you look. Most likely it has a set of outer red lens on the inner lamp assemblies. Take the inner lens off and remove the bulb. Look at the socket, not the bulb. Does it have one or two contacts in the socket? One contact would be for a backup bulb, two would be for tail light and brake light bulb.
It's possible that someone has the wrong bulb in there and nothing works.
Old Sep 24, 2008 | 03:45 PM
sweethence's Avatar
sweethence
LOL nice catch
we need pics of this alleged quad tail lamp shark I say
gills or egg crates ?
Old Sep 24, 2008 | 04:21 PM
bluestinger
Navigator
Originally Posted by sweethence
LOL nice catch
Defiantlt a 69, Its got Gills!! My fault, it was sold new in 70, built in late 69... I will check the sockets.
Old Sep 24, 2008 | 04:30 PM
bluestinger
Navigator
All the lenses are marked 68. All sockets have two prongs. All four lights come on when the break is pushed. The wireing harnes looks to be untouched...
Old Sep 25, 2008 | 01:07 AM
jyounane's Avatar
jyounane
Does it have the 68 style reversing lights below the rear bumpers? It's possible that harness & lamps were changed by someone to 68 style though I have no idea why. The VIN number would be useful....
Joe
Old Sep 25, 2008 | 07:37 AM
sweethence's Avatar
sweethence
So you have a 69 gilled vette with 68 lenses, and all four lamps light up but no reverse lamps? or are they on the lower valence like this
VIN and pics would help, but the simple truth is the car is ~40 years old, if it is a 69 someone probably just "personalized" it along the way.
You sure its not a 68? is the key on the dash or the colum
68's rock !!!!!
Cheers
tim
Old Sep 25, 2008 | 08:40 AM
bluestinger
Navigator
Very much a 69. key is on the column.
Old Sep 25, 2008 | 09:19 AM
sweethence's Avatar
sweethence
the only question remains do you want to put it back to stock or keep the quad tails?
when you say the wiring looks untouched, that just means that whoever modded the tail lights either didnt do a hack job or less likely though possible swapped in a 68 rear harness. Ether way if you want it back to original you have to ID the reverse lamp wiring, get the right inboard lenses and swap it back. simple project really dealers choice
tim
Old Sep 25, 2008 | 12:06 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The VIN will resolve all model year questions about your car. Car line series character is a 4 for all 68s (194678S4XXXXX ; a 7 for all '69s (194679S7XXXXX, and 4 again for all 70s. Model year designation also changes.
Looks to me like you've got a '69 running '68 tail lights.
Old Sep 25, 2008 | 02:20 PM
bluestinger
Navigator
Its OK as it is I wanted to check with the colective knowledg here for any other ideas... Someone must have made some changes to it at some time... Thanks for your input guys
Old Sep 25, 2008 | 06:59 PM
RPOL68's Avatar
RPOL68
Default Wiring Color Codes
The correct 1969 rear harness colors are:
Tail Lites & Side Markers - Brown
L Sig/Brake - Yellow
R Sig/Brake - Dark Green
Reverse Lites - Lt Green
Ground - Black
The outer lens are the same from 68 thru 73 so the guide # will be 68 on all of them.
I can't remember where that rear harness plug is located. It comes up the drivers side near the battery and I think across to the center console area. Someone here can check the AIM. If you need to trace the reverse lites you may need to check there if you can't locate a Lt Green wire at the light assemblies.
Remember all those C2's with six tail lights? Listen to Jan & Dean's Dead Man's Curve. I use to see a lot of those but they never came from the factory that way. I just can't see your car coming from the factory that way either.
To 69 mystery
