Jacobs ceramic boot kit, installation of
Old Sep 24, 2008 | 06:35 PM
LannyL81's Avatar
LannyL81
Default Jacobs ceramic boot kit, installation of
Do these boot attach to any 8.5mm plug wire or do you have to use Jacobs wire?
Old Sep 24, 2008 | 06:47 PM
ram82fire's Avatar
ram82fire
Mine came assembled ,,,,,,,,,, not sure if the ceramics are available loose packed
g
Old Sep 24, 2008 | 08:56 PM
mrvette's Avatar
mrvette
Yes, the ends are available alone about 130 bux/set of 8....pricey.....
BUT they don't BURN....or melt, I have 8 mm wire on them, and the wire is a bit loose...so yes your 8.8 should fit....
Old Sep 29, 2008 | 12:48 PM
LannyL81's Avatar
LannyL81
Well, got the PRICEY set of 8 and have a question; which end of the ceramic boot does the silcone boot go on...the end the plug goes into, or the end the wire goes into? It will fit either way. I think the plug end, but thought I would ask.
To Jacobs ceramic boot kit, installation of
