Headlight Door Adjustment
Old Sep 25, 2008 | 04:47 PM
STL'79's Avatar
STL'79
Default Headlight Door Adjustment
Bought a '79 L48 with pretty much everything original last month, my first Corvette ever! Only 68K on the odometer, garaged, and all maintenance kept up. I'm working out a couple issues (back end needs the new spring, speakers need replacement, etc) but one issue I haven't gotten a handle on yet is the headlight doors. They open and close just fine, but the back edge of the doors (the hinge side) scrape on the body every time they open or close, and it's caused some of the paint on both the door and the body to wear off as well as a little of the fiberglass. I laid on my back w/ a flashlight for an hour over the weekend trying to figure out the right way to move the doors a little forward, but can't figure it out. Any help?
Old Sep 25, 2008 | 06:35 PM
Artsvette73's Avatar
Artsvette73
Take a real good look at the support bar. Where the headlamps are bolted to. That support is glued to the fiberglass with an adhesive. If it has seperated you found your problem.
Old Nov 7, 2008 | 04:16 PM
STL'79's Avatar
STL'79
Artsvette73: Thanks. That's exactly what happened; the suppport separated, and had to be reglued. Took three weeks. // Why the AH-1 in the background of your picture - you a snake driver?
Old Nov 8, 2008 | 05:49 PM
vinsand's Avatar
vinsand
I think I have the exact same problem on my '75. What were the steps to reglue that strip?
Old Nov 10, 2008 | 05:36 PM
Artsvette73
I used Fusor made by the Lord Corp, The gun will cost around 65.00
http://www.lord.com/Home/ProductsSer...8/Default.aspx
To Headlight Door Adjustment
