my block is cracked
Old Sep 26, 2008 | 12:15 PM
Mikey74Stingray's Avatar
Mikey74Stingray
Default my block is cracked
I'm in the middle of having my engine rebuilt. I just found out it has a 3" crack in it. anybody ever heard of stitching? its a way to fix the block.
is if worth the trouble? I have another block i can get for $100
Old Sep 26, 2008 | 12:40 PM
WESCH's Avatar
WESCH
Hi
Nobody is stitching ( Metalocking ) this for 100 USD.
So it depends on you if you want to keep this block for any reason like numbers matching or so.
Metalocking seems to be the only way to permanently repair a block, but it is only repaired and Good knows how long it will hold.
http://www.inplace.com/machining/metalstitch.html
Good luck. Günther
Old Sep 26, 2008 | 12:54 PM
BarryK's Avatar
BarryK
the 327/365hp motor in my '65 had a crack by the freeze plug on the passenger side and was stitch welded back in 2004. It was well worth doing because it's the original motor from the car so the value is in keeping that particular original numbers matching motor.
you would not know where the repair was unless I pointed it out to you and I've since had that motor up past 7500rpm (6500rpm redline) and it's holding together well.
i'm told that where the stitch welding is done is actually now stronger than the rest of the block so strength is not an issue on this type of repair if done correctly.
The bigger question than strength is if your motor is the original motor for the car or not. If it is it's well worth doing. If it's not and you can get another good block for $100 you need to weigh the cost between the expense of having a shop do the stitch welding on your existing block vs the cost of the new block at $100 PLUS the cost of building the replacement motor from that new block.
Overall the stitch welding of your existing block will be less expensive than completely building a new motor but if you are looking to upgrade for higher performance, etc anyway than now may be the best time.
Old Sep 26, 2008 | 01:03 PM
stingr69's Avatar
stingr69
Get a different block. No sense pouring a lot of money in repairing and then rebuilding a cracked block unless there is a compelling reason.
-Mark.
Old Sep 26, 2008 | 02:35 PM
GaryS's Avatar
GaryS
1. Is this your original block? If so, keep it, fix it, rebuild it and reinstall it.
2. Is the $100 replacement block guaranteed? If so, and if your engine isn't the original one, then go for a rebuild. The downside to a used block is just that, it is used.
3. Have you looked at the GM crate engines? Lots of nice engines for a pretty decent price.
4. There is a very detailed article in the latest issue of the NCRS Driveline in which they repair an original engine with a similar crack in the block. They stitched the engine and rebuilt it prior to reinstallation.
Old Sep 26, 2008 | 04:21 PM
Mikey74Stingray
well its a matching number block so we're going to fix it. they said it would be around $150
Old Sep 26, 2008 | 04:45 PM
BarryK's Avatar
BarryK
good price it sounds like.
BTW, depending on where the crack is the motor may not even have to be disassembled and for that price the crack must be an in easy spot.
Where mine was they did it while the motor was still in the car and all assembled also.
Well worth that cost to keep the original numbers matching motor
Old Sep 26, 2008 | 05:29 PM
baxsom's Avatar
baxsom
me personally, numbers matching or not i wouldnt buy a car with a cracked block.
but thats just me, #s not matching on an otherwise good running car isnt an issue
Old Sep 26, 2008 | 06:46 PM
Duke94's Avatar
Duke94
I had the numbers matching block for my 71' fixed by stiching. Worked fine and doesn't leak. Don't recall what it cost, but I'm sure it was way more than 100 bucks.
Old Sep 26, 2008 | 08:16 PM
1nicecorvette's Avatar
1nicecorvette
yeah 100 sounds cheap to me too. maybe they are using alumalloy to fix it.
Old Sep 26, 2008 | 11:42 PM
BLOCKMAN's Avatar
BLOCKMAN
We have repaired quite a few cracked blocks over the years with this http://locknstitch.com/ with no problems so far.
Old Sep 26, 2008 | 11:50 PM
BLOCKMAN's Avatar
BLOCKMAN
Check out the stitching Frank Casey does as I have work on some blocks that his guy has repaired as I call him an artist.
http://speedtalk.com/forum/viewtopic...ighlight=casey
Old Oct 2, 2008 | 04:10 PM
Mikey74Stingray
Block is fixed. it wound up costing $200 but whatever its back and I'm happy
To my block is cracked
