5.3(lm4) Swap Pics
5.3(lm4) Swap Pics
It begins.... Just doing the basics of the swap right now..getting all of the old junk out of the way and getting the new motor ready..
So here it is! 5.3(lm4)..
The main electrical connectors from the engine harness
Test fitting the fbody accessory brackets
Comparison of the 5.3(bottom) and fbody(top) water pumps
Comparison of the 5.3(left) and fbody(right) water pumps
This is what happens when the bolt breaks while pulling the motor ..luckily it hit the stand and not my face
I will be removing all the old heater and ac parts..try and clean up the firewall a bit
Interesting swap. Keep the pics coming please. Sorry about the windsheild.
This belongs up in the LSX engine swap sticky thread. There have been some interesting 5.3L engine swap/build stories in the car magazines. They can be built to produce impressive HP. After all, they are a modern 327 ci engine. They are readily available at modest cost which makes them an attractive alternative to an LS1 engine. Keep the pictures and progress coming. I'm interested in your progress and ultimate performance of the engine.
Alright..decided to just pull the body off and see how much rust damage there was etc.I was very pleased..frame looks to be in very good shape. It will make the swap a little easier as well as installing the rack and pinion setup and the fuel pump setup. Gonna pressure wash, degrease, and then paint it up.
Engine hoist was shabby but it got it done
differential cross member looks decent
tailhousing seal was bad in the transmission im pretty sure..just had all the seals in the rearend done a few years ago..could be though. I will check it out!
While the body is off, it is a good time to pressure wash the underside of the body and paint your rocker channels. It is looking good! You can extend the lifespan of your fuel tank if you wire brush, chemically prep and paint with POR. I did mine in silver and it came out great. My results with POR paint have me using it wherever I can properly prep as suggested by the mfg. My gloss black and silver contrast produced outstanding results. Yours might be a candidate.
So I dont have all the bolts to the fbody brackets so i went to ACE to get some. Is there anything wrong with using these kind of bolts? ..iv used them before but I was just wondering. Also here is a picture of the truck altenator on the fbody bracket. IT WILL work. for you future 5.3ers
