Regular or premium?
Old Sep 29, 2008 | 05:46 PM
yel76low's Avatar
yel76low
Originally Posted by BHRIG
Boy has this become a discussion!!!!!!
My original question was "what octane gas was the 1977 L48 engine designed to run on?"
If I was running 93 octane fuel and changed to 87 octane fuel would other adjustments be required?
The motor is strictly stock....NO COMPUTER!!!!!! The car is a daily driver
The responses have been interesting....from what I've read there would be very little difference in engine performance but I could save .40-.50 cents a gallon.
12 gallons = $6.00 at each fill. Not bad, eh?
It has turned into quite a discussion... but back to your original question:
You don't need to change anything to run 87, because that's what the car was designed to run on. 93 octane (or 110) won't give you any advantage in your engine, because it is designed to run on 87 octane.
Now, if you had a newer engine that was designed for 91 octane, and is computer controlled, its a different story. It will run best on 91 octane, but it will still run at 87 octane because the computer will retard the timing. The changing of timing will affect the combustion (and ultimately your sfc, or the mpg you get.)
Summary: 87 for the win
Old Sep 30, 2008 | 09:51 AM
SoCalErv's Avatar
SoCalErv
Army
No.
With the assumption of increased fuel cost and improved mileage from running premium rather than regular you pickup $.0031/ gallon. On 15 gallons that is $.05 per tank.
I agree that running premium will not help your stock engine. I would also run my own fuel comparisons, however in the end, if the assumptions are correct it is a wash.
Old Sep 30, 2008 | 09:56 AM
a1sensei's Avatar
a1sensei
Old Sep 30, 2008 | 12:45 PM
Mike Ward's Avatar
Mike Ward
Originally Posted by pbcanney
I actually tried something in my truck at the beginning of the summer and recommend everyone try it at least once.
I typically get 17.4 mpg on regular, but ran the tank down and filled it with premium (20 cents more per gallon). At the next fill up, I had clocked an extra 1.5 mpg.
Now thats a heavily regulated by computer fuel system in my 08 ranger, compared to the weaker than an Atari 2600 in an '81... So considering we're all dealing with 30+ year old technologies, I would recommend testing a few tank fulls. It's obviously a better grade than the homogenized stuff you're "saving money with" pumping regular.
saving money.... 20 cents / 10 gallons .. 2 bucks.
wow....
Being that high octane fuel has less energy (fewer BTUs) per volume than low octane gas, and that you made no changes in timing, compression or carburation how do explain that your mileage went up?
Old Sep 30, 2008 | 02:25 PM
BHRIG's Avatar
BHRIG
Default Regular or Premium
I never said mileage went up! When I computed the cost of a fill-up,not counting the actual miles driven, it was strictly on 12 gallons of fuel @ a savings of .50 per gallon ($6.00).
If anyone else is like me they spend as much time with engine running, and not driving......How else can you adjust,fix,or play with your engine.
I really never tried to check MPG because I would cry.....
I enjoy trying to improve a basket case I bought 7 years ago to work on because I like working on cars!!!
Old Sep 30, 2008 | 04:39 PM
Mike Ward's Avatar
Mike Ward
I realise that, I was asking how pbcanney did it. Not trying to hijack your post.
I'm glad you've seen through the mist and realised that there's nothing to be gained (and dollars to be saved) by using the correct fuel, 87 octane in your case.
Old Sep 30, 2008 | 06:28 PM
kapla74's Avatar
kapla74
Hi there, back in argentina we have a lot of difference between regular (85 octanes), super around 95 and premium 98+ even 100 octane on regular gas station. I always used my car on super fuel, its a 1973 l-82 stock. I Always wondered if it will run ok with regular even if its 85 octanes here? prices though are in a 50cents difference between each type of fuel.
Will this affect the engine?
Old Sep 30, 2008 | 09:41 PM
Mike Ward's Avatar
Mike Ward
The octane rating system might be different in Argentina than it is in North Americae. I know that Europe has a different system than us.
In any case, you should always use the use the lowest octane rating fuel possible that does not allow knocking or pinging to occur.
Your '73 was built to run on low octane unleaded fuel.
Old Sep 30, 2008 | 10:08 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
....and stop in at Sunoco and buy a tank of 93 every once in a while to clean 'er out
Old Sep 30, 2008 | 10:45 PM
dave_roads's Avatar
dave_roads
a few points to ponder in this discussion is the formulation differences coming from the refineries from 1977 to present, ie. the absence of lead (which your car was maybe designed to run on((i don't know)), the blend differences for different regions of the U.S. (87 oct. is not the same as 87 oct. in s. Florida, etc...) I can buy regular pump gas and run fine all day long here in s. texas but sluggish. But, i can also go buy a tank of 100+ VP racing fuel and there is a night and day difference. There are several detailed discussions on the subject posted in the past. I'm no expert, but there is definately is a difference as I think the original poster experienced.
Old Oct 1, 2008 | 08:46 AM
Mike Ward's Avatar
Mike Ward
Well here we go again with 'myths' taken precedence over science and fact.
No Corvette built after 1971 needs lead in the gas. Even those built before this date will not suffer the dreaded valve recession that was a big fear in the 70s.
Regarding 'cleaning out the engine', all grades of gas contain sufficient cleaners to do the job. Very few carburated engines ever get dirty enough to need any cleaner, but that's another story.
And once again, high octane or 'racing gas' contains less energy (fewer BTUs per unit) than regular. So if you guys want to throw your money away, please throw it my way instead.
At least I'll say thanks.
Old Oct 1, 2008 | 09:19 AM
BHRIG's Avatar
BHRIG
Let me sum up the responses so far........NO problem using 87 octane fuel in my stock 1977 L48.......Higher octane fuel will not make an engine run better if engine was NOT designed to run on it........There if no need to make adjustments to timing as long as engine does not knock...........
I should get less MPG with 87 octane.........I could save $ by changing to 87 octane fuel(added benefit)......
THERE ARE MANY PROS AND CONS TO THE CHANGE, THERE ARE MANY OPINIONS, some factual,some mythological....all input is appreciated.
This forum is so helpful as a tool to help form a persons opinion!!!
Old Oct 1, 2008 | 09:43 AM
  #33
...Roger...'s Avatar
...Roger...
My motor is a stock 1977 L48. What octane fuel is required?
How will premium fuel effect (help) performance?
I have been using premium fuel for about six years and just recently read the motor only required regular fuel.
What is the consensus?
Thanks for responses.
Originally Posted by a1sensei
Premium fuel is a waste of money for your stock engine. Octane stops detonation, period! If your engine does not knock with regular (and with the low compression you have, it won't), there is no advantage to using premium.
God bless, Sensei
BHRIG you haven't mentioned how your car is tuned.Stock or tweaked for performance.If you want to tune for performance IMO you can do this with premium without as much fear of detonation.Its all in what you want performance,milage,cheap fuel ??? Tune it with regular and check mileage and perf. Then tune it with premium and check mileage and perf.Bottom line is your car will(should)run on regular providing you dont have a bunch of carbon buildup raising the compression high enough to cause detonation or the carbon creating hot spots.
Old Oct 1, 2008 | 12:26 PM
  #34
Mike Ward's Avatar
Mike Ward
All correct except :
'I should get less MPG with 87 octane'
You will not decrease mileage with low octane, conversely not increase it with high octane.
There no pros to using the incorrect fuel (unless you like wasting money)
Old Oct 1, 2008 | 02:56 PM
  #35
BHRIG's Avatar
BHRIG
DWnchs. Sorry you had a lot to assume.
I did say I had a stock 1977 L48 motor.
It has nothing tweaked other than boosting vac advance to 12 degrees before TDC. This done with can disconnected.
I will try 87 octane and adjust as necessary
