side pipe pictures
Old Sep 28, 2008 | 09:53 PM
jagan's Avatar
jagan
Default side pipe pictures
I need pictures of 69' style sides pipes and how they mount to the rockers. Are there exposed bolt heads? Any help would be great.
Old Sep 29, 2008 | 03:55 PM
Alan 71's Avatar
Alan 71
Hi J,
If you're asking about the covers... there are 6, counter sunk, oval head, cross slotted, screws, per side. You can see the heads of the screws and they are black like the part of the cover they go through.These screws mount to the rocker panel of the birdcage right below the bottom edge of the door.
In addition there are 2 connections from the cover to the frame that you can't see unless you're under the car.
The pipes themselves mount at the exhaust manifold and the at the other end of the muffler very near the outlet. This rubber mount bolts to the frame.
Regards,
Alan
