bolt size questions, PLEASE HELP
Old Sep 28, 2008 | 11:16 PM
Bowerss2's Avatar
Bowerss2
Default bolt size questions, PLEASE HELP
Hey all, i have some questions about some bolts.
1)What is the size for the bolts that hold on the front calipers.
2) what is the size for the bolts that hold the power steering pump and bracket on?
thanks all,
Steve
Old Sep 28, 2008 | 11:31 PM
sly vette's Avatar
sly vette
#2...9/16
Old Sep 28, 2008 | 11:33 PM
TimAT's Avatar
TimAT
I don't remember the front caliper bolts, but the power steering is all 3/8 bolts except for the support that comes off the back of the pump and goes to the front exhaust manifold bolt. That one I think is 3/8 into the head and 5/16 thru the bracket. Or maybe the other way around.
Is that what you need or do you need grip length and thread ?
Old Sep 28, 2008 | 11:47 PM
Bowerss2's Avatar
Bowerss2
Originally Posted by sly vette
#1...5/8
#2...9/16
do you know the thread and length?
Old Sep 28, 2008 | 11:55 PM
TimAT's Avatar
TimAT
OK, I don't have a clue what the lengths are but I can tell you that the 3/8 bolts have a 9/16 head and are USS (course) thread.
Old Sep 29, 2008 | 10:48 AM
jnb5101's Avatar
jnb5101
the front caliper bolts are shorter that the rear bolts. they are fine thread 9/16 hardened. i believe the fronts are 1 1/8".
Old Sep 29, 2008 | 11:24 AM
Project80's Avatar
Project80
Rear caliper bolts on my 80 are actually 9/16, fine thread - Grade 8.
Old Sep 29, 2008 | 12:52 PM
JIM's Avatar
JIM
Bolt sizes are determined by Diameter and Threads Per Inch.
Old Sep 29, 2008 | 03:06 PM
...Roger...'s Avatar
...Roger...
caliper bolts are 7/16-20X1 1/4"
Old Sep 29, 2008 | 03:27 PM
jnb5101's Avatar
jnb5101
dw is correct 7/16 not 9/16- what can i say, it's monday!
Old Sep 29, 2008 | 03:53 PM
...Roger...
These are power steering bolts and nuts.
(2) 3/8-16x3", black phosphate, grade 5 bolts,
(1) 3/8-16x3/4", zinc, grade 5 bolt, (2) flat washers, (2) nuts, & (5) lock washers.
Old Sep 30, 2008 | 11:40 AM
Project80's Avatar
Project80
Yes, 7/16 - 20, not 9/16.
This is a grade 8, fine thread bolt which is difficult to find around my area.
Anyone know of a vendor that sells by the piece, not by the box?
Old Sep 30, 2008 | 11:54 AM
JIM's Avatar
JIM
Do you have a hardware store that has those slide out boxes?
Old Sep 30, 2008 | 01:38 PM
...Roger...
http://willcoxcorvette.com/product_i...oducts_id=4678
I think its like Hillman products.
Old Sep 30, 2008 | 09:29 PM
Project80's Avatar
Project80
Everyone has Grade 8 in a coarse thread, just not in fine thread. I can even get the coarse thread in stainless steel! It seems like all the independent Auto Supply Stores are gone. They used to have large assortments of Doorman/Motormite hardware. As a matter of fact, there is only one real machine shop left that I would trust with more than a lawnmower engine.
Old Sep 30, 2008 | 09:36 PM
TimAT's Avatar
TimAT
Find a Caterpillar tractor dealer- those guys have grade 8 (and BETTER than grade 8) bolts in all sizes. I got new rear spring hangar bolts from them..
Old Sep 30, 2008 | 09:44 PM
Project80's Avatar
Project80
Great! There is actually a dealer only 14 miles away.
To bolt size questions, PLEASE HELP
Old Oct 1, 2008 | 05:43 PM
...Roger...
If you have an Ace Hardware in your area in the back of the store is usually a wall of cardboard drawers with bolts and fasteners.Hillman is the name of the company. Hillman #2377-C is 7/16"x20x1-1/4" Grade 8...$.90 each
Old Oct 2, 2008 | 09:29 PM
Project80's Avatar
Project80
There is a large Ace hardware store in my area, I even have a rewards card! Unfortunately, all of the fasteners are in an employee access area only. You have to tell an Ace Hardware employee at the counter what you want. This is the first place I tried only to be told by a teenager that they only stock Grade 8 in a coarse thread. I am getting too old to jump over counters.
Old Oct 2, 2008 | 11:42 PM
JIM's Avatar
JIM
OK to get really technical it's a .437-20 UNF-2B x 1 1/4
I cant help it I'm a mechanical designer.
Have you tried a Chevy dealer?
How many do you need?
