1972 Steering column
Old Sep 30, 2008 | 12:09 PM
Elkhartgreen72's Avatar
Elkhartgreen72
Default 1972 Steering column
Hello gang,
As most of you know, I am restoring a 72 coupe. I am up to the steering column. It's out of the car , on the work bench. It is a straight column, no tilt, no tele. Just a turn signal. The wheel is off, the rag joint is off. (both are easy enough). I might add, I could send it out but I would like to tackle it myself. I have been looking for a diagram of the parts in order, but can't find one. Does anyone have one thay can send me? Also the main bolt of'course spins the shaft. What's the best way to unbolt that? I would like to completely dis assamble it, restore each part and re assemble and repaint it. I'm just asking for anyones advice that may have done this job before. Any pit falls I may run into. Any short cuts, any sequence I might need to follow.
Thank you in advance
Elkhartgreen72 (Dave)
Old Sep 30, 2008 | 01:55 PM
jnb5101's Avatar
jnb5101
see jim shea's papers at covettefaq.com
Old Sep 30, 2008 | 01:59 PM
Gordonm's Avatar
Gordonm
I have a 79 column to go into my 72. I have one 79 T&T column all apart and another all together. Going to make 1 good one out of the two. Follow Jims paper on steering columns.
http://jimshea.corvettefaq.com/?page_id=4
Old Sep 30, 2008 | 02:22 PM
TimAT's Avatar
TimAT
Gordonm has it. The FINAL authority on steering is Jim Shea.
Old Sep 30, 2008 | 03:28 PM
Elkhartgreen72
Thanks to all, Everyone sais JIM SHEA's The man.... I'll check it out
Thanks, again
To 1972 Steering column
