My experience was the same as Chris (71 roadster). After your shims are removed (which is the hardest part) you will have space to use a sawzall with a 6" blade. The bolts will probably be seized in the bushings. If you can't remove the bolts you'll have to put in new bushings. I don't like the torch method. Tom
Chuck, When I did the rear bearings the T/A were just hanging. I did not do the t-arms as they are in good shape. A little bit of surface rust but I do not worry about that. I only learned of a possible alignment problem after the fact. On the bearings, we ruined one spindle by applying 20-ton pressure at a local machine shop to get the old bearings off. The end mushroomed. Scared the &**& out of me when it snapped. This is not a job for amateurs. It seemed to be a lack of grease in 1979 at the factory. The original bearimgs were dry. That I would not recommend for most home mechanics.
Hi paul,
I did this job in August. I tried the sawzall method, however I had a couple
of poor quality blades. The teeth came off and only scratched the bolt.
It was on a Sunday and nothing open.
Nuts came off ok, however I had non slotted shims.
So I drilled a small hole in the bolt, (thru the shims), with no problem.
Then used a larger drill and increased the size of the hole.
I kept doing this until the bolt was severed.
Took about 10 minutes.
This worked for me, however all the suggestions should work.
Barry
All of this talk of Torches and saws has me thinking the lot of you is a carne insana!
My bolts were frozen and rusted.
I hit it with a butt load of penetrating oil. Then backed the bolt with a wrench and used a box wrench with a cheater pipe to break the nut loose. The bolt still wouldn't come out. I got the bolt as far as I could with a hammer then made this handy tool from a huge nail at home depot. I put it in my bench vise and heated the places I was bending with a propane torch to make them a little more maleable.
Use it like this (imagine the tire not being there):
It took me maybe an hour to get each side done. my bushings were shot all to hell too.
Once you have the bolt recessed a little smack this puppy with a 5 lb sledge. It may take a little bit but at least it allows you to punch the bolt out without fear of whacking your fender.
