Steam Holes
Old Oct 1, 2008 | 07:00 PM
qwik-tripp's Avatar
qwik-tripp
Default Steam Holes
I have a set of RHS 220 Iron heads, are the steam holes needed in the heads? The deck thickness of the heads seem to be way thicker than GM heads and I'm not real comfortable drilling that deep if not really needed.
400 519 block .030 10.4:1 Thanks
Old Oct 1, 2008 | 08:21 PM
Durango_Boy's Avatar
Durango_Boy
Yes, you will need the steam holes.
I would not recommend doing them free hand with a power drill. If you don't have the ability to jig the head into a drill press or mill and do it right then I would suggest dropping the heads off at a machine shop and have them drill the holes.
Here locally it's only $40 - $50 to have the steam holes drilled.
Old Oct 1, 2008 | 09:09 PM
hugie82's Avatar
hugie82
steam holes are a must on sbc400
Old Oct 2, 2008 | 01:26 AM
jackson's Avatar
jackson
Several aftermarket iron sbc blocks available ... and those with siamezed cylinders (like OE 400) do not have steam holes in block ... I see this in both 4.000 & 4.125 aftermarket iron sbc blocks.
Seems like maybe member "Motorhead" may've recently completed a siamezed aftermarket sbc about 427"??? wonder if he had steam holes in block/heads?
Wondering why? ... if OE must have them ... why not aftermarket also?
Old Oct 2, 2008 | 03:28 PM
Belgian1979vette's Avatar
Belgian1979vette
Most aftermarkets are considered race blocks and they also have bigger bore walls, which would interfere with the steamholes. It was said that the steamholes were only necessary below 3000 rpm.
Old Oct 2, 2008 | 03:46 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Originally Posted by Belgian1979vette
Most aftermarkets are considered race blocks and they also have bigger bore walls, which would interfere with the steamholes. .
BUT, I would just go ahead and do them. I've read lots of debate about the need or lack of it for the steam holes, but didn't ever see anything conclusive or side by side.
The bottom line is that they are easy to do if you have a drillpress. If not, is it worth saving $50 and then wondering if this is the reason that you're having overheating problems?
Old Oct 2, 2008 | 04:06 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I would drill them if the heads are going on a block that has them
The Motown block I have doesn't have steam holes, it has enlarged areas around the cylinders for extra cooling, kinda hard to see but you can see the bulges at each cylinder in the second pic
Old Oct 7, 2008 | 02:05 PM
jackson's Avatar
jackson
Default Dart's take on (block) steam holes
Interesting response from Dart when asked about steam holes in block.
jackson's Q:
I see new 4.125" bore SHP block looks nice. Seems 4.125" bore block does not have steam holes. Is that so? If so, why does 4.125" SHP not need steam holes.
Dart's A:
None of our 4.125 bore blocks have steam holes, they are the same blocks as the 4.000 bore blocks as well. The reason the factory blocks have them is more of a design flaw than a need. They factory blocks have a pocket where the air could not escape and would cause a steam pocket, therefore the engines would run hot, the idea of the steam holes would be to allow that steam (air pocket) to release and fill with water. They only get used once, from there the air pocket is filled and never again will they make steam inside a sealed water jacket that is full. Our blocks are designed internally in a way to increase coolant capacity, and without any voids, or pockets that water can not get to during that initial fill.
John Keyes
Dart Machinery, Ltd.
Phone: (248) 362-1188 ext. 105
Fax: (248) 362-2027
jkeyes@dartheads.com
Old Oct 7, 2008 | 03:24 PM
Belgian1979vette
jackson's Q:
Dart's A:
John Keyes
Fax: (248) 362-2027
Seems a reasonable explanation, if they don't think they are necessary I would use their blocks as such.
To Steam Holes
