Compresion and torque?
Old Oct 3, 2008 | 09:30 AM
sly vette's Avatar
sly vette
Default Compresion and torque?
How does compression affect torque? I will be building a BBC 454 in the future,and am doing some preliminary research.
Mark
Old Oct 3, 2008 | 11:42 AM
wfo76's Avatar
wfo76
More compression definitely adds torque, power and fuel economy.
Vizard says raising compression from 9:1 to 11:1 adds 3.2% more power with a
street cam and even more with a longer duration cam.
Also says that fuel economy gains will be about double the power gains in percentage.
Old Oct 4, 2008 | 01:24 AM
yel76low's Avatar
yel76low
9 to 11 is a really large jump - you wouldn't build a 454 with 11:1, would you? Anyway, I would expect to see slightly more than 3.2% for 2 compression points. But I sure wouldn't put a number on it.
And yes, CR has a much larger effect on efficiency than power. This is due to the fact that the higher compression ratio results in less loss (percentage wise) in pumping work.
Old Oct 4, 2008 | 10:12 AM
howarsc's Avatar
howarsc
It all depends on cam selection and where you want to be power wise. There is a striking difference in tq with 9:1 vs 11:1 in a big block.
Old Oct 4, 2008 | 02:44 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Just changing the compression won't do much, you need to change the cam at the same time. Basically speaking you increase the CR and put in a bigger cam you will make more power, more power means more torque.
It will move the peak torque up to a higher RPM but you will still have more torque throughout the entire RPM range than a lower compression motor with a smaller cam
To Compresion and torque?
